Can you have Java compiled straight into machine code?
I want to do this so I have control over what platforms it's used on, and don't know C,C++ etc.
It appears that the GNU Compiler for Java can convert Java source code into either Java bytecode or machine code. It can also convert existing Java bytecode into machine code. However, the last news is from 2009, so I'm not sure how current it is and if it can handle the latest features of the Java language.
Not quite directly answering the OP, but an perhaps an interesting aside. Java can be run in three modes:
-Xint
flag - Interpreted - Byte code only-Xcomp
flag - Compiled - machine compiled-Xcomp
because I could not find that one in the JDK 7 documentation or the HotSpot options documentation and not sure if you have some hidden mailing list secrets that we, the mere mortals, are not aware of :-)
– edalorzo
Oct 30 '12 at 05:45
javac
? when using the -Xcomp does it by default output a single binary file?
– Alexander Mills
Apr 19 '19 at 00:04
java
, that is how the JIT compiler operates during runtime
– Martijn Verburg
Apr 20 '19 at 15:47
It might be better to detect the operating system using System.getProperty(“os.name”). That would let you choose to support more than one OS, but exclude others.
java -Dos.name=MacOS
– hellodanylo
Sep 18 '12 at 18:51
It is now: GraalVM allows you to compile your programs ahead-of-time into a native executable. Take a look at native-image feature:
Summary
https://www.graalvm.org/docs/getting-started/#native-images
Demos: Native images for faster startup
https://www.graalvm.org/docs/examples/native-list-dir/
Detailed: 'Ahead-of-time Compilation'
https://www.graalvm.org/docs/reference-manual/aot-compilation/
Related question: 'Can I compile Java to native code?' https://stackoverflow.com/questions/2991799/can-i-compile-java-to-native-code/50555050#50555050
P. S. GCJ isn’t maintained anymore.
Source: 'The Deletion of gcj' http://tromey.com/blog/?p=911
