When you debug optimised code, I know that address arithmetic doesn't work correctly:
0:004> u dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x69
dwmcore!CPartitionVerticalBlankScheduler::PresentFrame+0x15:
000007fe`f97420f1 81eca0000000 sub esp,0A0h
000007fe`f97420f7 33db xor ebx,ebx
000007fe`f97420f9 458ad1 mov r10b,r9b
000007fe`f97420fc 418be8 mov ebp,r8d
000007fe`f97420ff 488bf2 mov rsi,rdx
000007fe`f9742102 488bf9 mov rdi,rcx
000007fe`f9742105 389a10010000 cmp byte ptr [rdx+110h],bl
000007fe`f974210b 740c je dwmcore!CPartitionVerticalBlankScheduler::PresentFrame+0x26d (000007fe`f9742119)
Offset 0x69 from dwmcore!CPartitionVerticalBlankScheduler::WaitForWork
is actually in another function. So how does windbg manage to correctly apply the dwmcore!CPartitionVerticalBlankScheduler::PresentFrame
symbol to an offset 0x54 from dwmcore!CPartitionVerticalBlankScheduler::WaitForWork
when the pdb clearly must contain another address for the symbol that is at a much greater offset than 0x54 for the original unoptimised code?
When you disassemble the WaitForWork function, it somehow manages to resolve the original offsets such that you can see what dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x69
really means
uf dwmcore!CPartitionVerticalBlankScheduler::WaitForWork
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork:
000007fe`f9742088 48895c2408 mov qword ptr [rsp+8],rbx
000007fe`f974208d 57 push rdi
000007fe`f974208e 4883ec20 sub rsp,20h
000007fe`f9742092 833d6ba50d0000 cmp dword ptr [dwmcore!Microsoft_Windows_Dwm_Core_Provider_Context+0x24 (000007fe`f981c604)],0
000007fe`f9742099 488bd9 mov rbx,rcx
000007fe`f974209c 48bf0100000000000080 mov rdi,8000000000000001h
000007fe`f97420a6 0f856bfc0600 jne dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x20 (000007fe`f97b1d17)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x5c:
000007fef97420ac 488b4b18 mov rcx,qword ptr [rbx+18h] 000007fe
f97420b0 488d5370 lea rdx,[rbx+70h]
000007fef97420b4 e8b7f1ffff call dwmcore!CPartitionManager::GetWork (000007fe
f9741270)
000007fef97420b9 833d44a50d0000 cmp dword ptr [dwmcore!Microsoft_Windows_Dwm_Core_Provider_Context+0x24 (000007fe
f981c604)],0
000007fef97420c0 8bd8 mov ebx,eax 000007fe
f97420c2 0f859dfc0600 jne dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x74 (000007fe`f97b1d65)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0xb4:
000007fef97420c8 8bc3 mov eax,ebx 000007fe
f97420ca 488b5c2430 mov rbx,qword ptr [rsp+30h]
000007fef97420cf 4883c420 add rsp,20h 000007fe
f97420d3 5f pop rdi
000007fe`f97420d4 c3 ret
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x20:
000007fef97b1d17 8a05eba80600 mov al,byte ptr [dwmcore!Microsoft_Windows_Dwm_Core_Provider_Context+0x28 (000007fe
f981c608)]
000007fef97b1d1d 3c04 cmp al,4 000007fe
f97b1d1f 7308 jae dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x2e (000007fe`f97b1d29)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x2a:
000007fef97b1d21 84c0 test al,al 000007fe
f97b1d23 0f858303f9ff jne dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x5c (000007fe`f97420ac)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x2e:
000007fef97b1d29 48853dc0a80600 test qword ptr [dwmcore!Microsoft_Windows_Dwm_Core_Provider_Context+0x10 (000007fe
f981c5f0)],rdi
000007fef97b1d30 0f847603f9ff je dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x5c (000007fe
f97420ac)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x37:
000007fef97b1d36 488b0dbba80600 mov rcx,qword ptr [dwmcore!Microsoft_Windows_Dwm_Core_Provider_Context+0x18 (000007fe
f981c5f8)]
000007fef97b1d3d 488bc1 mov rax,rcx 000007fe
f97b1d40 4823c7 and rax,rdi
000007fef97b1d43 483bc1 cmp rax,rcx 000007fe
f97b1d46 0f856003f9ff jne dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x5c (000007fe`f97420ac)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x49:
000007fef97b1d4c 488b0d4db10600 mov rcx,qword ptr [dwmcore!Microsoft_Windows_Dwm_CoreHandle (000007fe
f981cea0)]
000007fef97b1d53 488d15e6fd0500 lea rdx,[dwmcore!EVTDESC_SCHEDULE_WFW_Start (000007fe
f9811b40)]
000007fef97b1d5a e871f30100 call dwmcore!TemplateEventDescriptor (000007fe
f97d10d0)
000007fef97b1d5f 90 nop 000007fe
f97b1d60 e94703f9ff jmp dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x5c (000007fe`f97420ac)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x74:
000007fef97b1d65 8a0d9da80600 mov cl,byte ptr [dwmcore!Microsoft_Windows_Dwm_Core_Provider_Context+0x28 (000007fe
f981c608)]
000007fef97b1d6b 80f904 cmp cl,4 000007fe
f97b1d6e 7308 jae dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x83 (000007fe`f97b1d78)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x7f:
000007fef97b1d70 84c9 test cl,cl 000007fe
f97b1d72 0f855003f9ff jne dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0xb4 (000007fe`f97420c8)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x83:
000007fef97b1d78 48853d71a80600 test qword ptr [dwmcore!Microsoft_Windows_Dwm_Core_Provider_Context+0x10 (000007fe
f981c5f0)],rdi
000007fef97b1d7f 0f844303f9ff je dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0xb4 (000007fe
f97420c8)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x8c:
000007fef97b1d85 488b0d6ca80600 mov rcx,qword ptr [dwmcore!Microsoft_Windows_Dwm_Core_Provider_Context+0x18 (000007fe
f981c5f8)]
000007fef97b1d8c 488bc1 mov rax,rcx 000007fe
f97b1d8f 4823c7 and rax,rdi
000007fef97b1d92 483bc1 cmp rax,rcx 000007fe
f97b1d95 0f852d03f9ff jne dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0xb4 (000007fe`f97420c8)
dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0x9e:
000007fef97b1d9b 488b0dfeb00600 mov rcx,qword ptr [dwmcore!Microsoft_Windows_Dwm_CoreHandle (000007fe
f981cea0)]
000007fef97b1da2 488d15a7fd0500 lea rdx,[dwmcore!EVTDESC_SCHEDULE_WFW_Stop (000007fe
f9811b50)]
000007fef97b1da9 448bc3 mov r8d,ebx 000007fe
f97b1dac e8e3240200 call dwmcore!Template_q (000007fef97d4294) 000007fe
f97b1db1 90 nop
000007fef97b1db2 e91103f9ff jmp dwmcore!CPartitionVerticalBlankScheduler::WaitForWork+0xb4 (000007fe
f97420c8)
You can see that offset 0x69 from WaitForWork really means offset 0x31. So why does windbg just not detect that it is optimised and recalculate offsets to avoid the confusion and just say 0x31 in the stack trace as the symbol name, it clearly has the ability to do so. Furthermore, how does it even get the original symbol (symbol offset) for the address right (which was my first question). Does it compare instruction bytes? I found this link but it only tells you what happens, which I already know, and not how.
