While debugging and reverse-engineering my exe, I have found a very weird thing.
call ds:GetModuleFileNameA
This call instruction is formed with below hex bytes in IDA.
FF 15 24 C0 41 00
(I think that 0x41C024 means the index of Import Table)
But when I looked this call instruction while debugging it looks as follow.
FF 15 24 C0 1A 00
(Of course, image base is changed 190000 from 400000)
But what I don't understand is how OS (I use win10) automatically changed all offsets in code area.
Can anybody explain?
user202729
  • 675
It is Called Relocation
Every Executable has a section called .reloc
this Section contains details about all addresses that needs to be patched if the imagebase changes
the loader uses this section to change all the modified base address
for example win7 x86 32 bit calc.exe
disassembly from cdb.exe (randomised image base )
002616a3 ff15f4132600    call    dword ptr [calc!_imp__LoadStringW (002613f4)]
disassembly from dumpbin (default imagebase)
C:\>dumpbin  /nologo c:\Windows\System32\calc.exe /disasm /range:0x10016A2,0x10016b1
  010016A2: 50                 push        eax
  010016A3: FF 15 F4 13 00 01  call        dword ptr [__imp__LoadStringW@16]
if you look at the .reloca section you will notice a HIGHLOW entry for address 6A5
Offset(h) 00 01
000B9C00  00 10  ..
000B9C02  00 00  ..
000B9C04  B4 00  ´.
000B9C06  00 00  ..
000B9C08  41 36  A6
000B9C0A  52 36  R6
000B9C0C  A5 36  ¥6 <<<<<
000B9C0E  B3 36  ³6
so the loader can patch the address at RVA ( ImageBase + base of Section + address )
imagebase = 0x1000000 + base of section = 0x1000 + HIGHLOW address = 6a5
= 0x10016a5
at this address dumpbin has F4 13 00 01 whereas cdb has f4 13 26 00
the loader has patched it according to the image base
this post of mine has more details about what is patched
update wrt comment some exes dont have .reloc
yes it is entirely possible to have exes without reloc
infact there is a msvc linker switch /FIXED if passed produces exes without relocations
in most of the cases exes can survive without relocations because they are the first to be loaded in Process Address Space
so they tend to get their Preferred ImageBase always
Relocations matter most with Dlls especially those dlls that woud be Dynamically Loaded or loaded as a dependency to another dll
in this case clashes can happen and os needs a mechanism to relocate the binary in question
if windows cant relocate the dll it crashes the application with
C:\>cdb -c "!error c0000018;q" cdb | tail -n 3
0:000> cdb: Reading initial command '!error c0000018;q'
Error code: (NTSTATUS) 0xc0000018 (3221225496) - {Conflicting Address Range}  The specified address range conflicts with
 the address space.
quit:
blabb
  • 16,376
  • 30
  • Did you mean ASLR? – Biswapriyo Dec 05 '18 at 21:55
  • Perfect answer! – Luis Bergmann Dec 06 '18 at 03:37
  • Hi, blabb, You seem to know the process of windows execution. Can you please help me to run exe from memory? I need to load executable from network and save it to memory and execute it without creating new exe instance. Thanks in advance. – Luis Bergmann Dec 06 '18 at 04:33
  • I have looked some executables with pe explorer and some of them haven't reloc section. In that case, how loader relocate the address? – Luis Bergmann Dec 06 '18 at 04:43
  • @LuisBergmann wrt running exe from memory is kinda frowned upon and today os also have been much hardened to resist such process creation so it isnt a cut and dried recipe wrt to no reloc section i have edited my answer and added some details take a look – blabb Dec 06 '18 at 17:13
