How exactly did you set the path? Can you confirm the output of pwd
changes?
get_current_dir_name()
will malloc(3)
an array big enough to hold the absolute pathname of the current working directory. If the environment variable PWD
is set, and its value is correct, then that value will be returned.
Source
Which operating system do you use?
Under Linux, the function getcwd() is a system call (since 2.1.92).
On older systems it would query /proc/self/cwd.
Straight from the kernel source:
* NOTE! The user-level library version returns a
* character pointer. The kernel system call just
* returns the length of the buffer filled (which
* includes the ending '\0' character), or a negative
* error value. So libc would do something like
* char *getcwd(char * buf, size_t size)
* int retval;
* retval = sys_getcwd(buf, size);
* if (retval >= 0)
* return buf;
* errno = -retval;
* return NULL;
SYSCALL_DEFINE2(getcwd, char __user *, buf, unsigned long, size)
int error;
struct path pwd, root;
char *page = (char *) __get_free_page(GFP_USER);
if (!page)
return -ENOMEM;
get_fs_root_and_pwd(current->fs, &root, &pwd);
error = -ENOENT;
spin_lock(&dcache_lock);
if (!d_unlinked(pwd.dentry)) {
unsigned long len;
struct path tmp = root;
char *cwd = page + PAGE_SIZE;
int buflen = PAGE_SIZE;
prepend(&cwd, &buflen, "\0", 1);
error = prepend_path(&pwd, &tmp, &cwd, &buflen);
spin_unlock(&dcache_lock);
if (error)
goto out;
/* Unreachable from current root */
if (!path_equal(&tmp, &root)) {
error = prepend_unreachable(&cwd, &buflen);
if (error)
goto out;
error = -ERANGE;
len = PAGE_SIZE + page - cwd;
if (len <= size) {
error = len;
if (copy_to_user(buf, cwd, len))
error = -EFAULT;
} else
out:
path_put(&pwd);
path_put(&root);
free_page((unsigned long) page);
return error;
TL;DR
glibc only specifies a stub looking up the PWD variable, it it is not set, the filesystem implementation has to handle the job
