I am trying to attach the WinDBG to particular process but I constantly get the error below :
I am using win 7 x64 and am trying to debug x64 application.
I run the IDA Pro with admin privileges. I have run the application both with admin privilege and the user one. I even tried to run it on different windows user account with admin privilege but I still get the same error.
Asked
Active
Viewed 6,446 times
FreeMind
- 639
- 3
- 9
- 17
The target process may have anti-attach protection. See this post. – 0xec Aug 29 '15 at 16:59
@ExtremeCoders The problem is I can easily attach to the process in x64_DBG. This issue occurs only in IDA Pro – FreeMind Aug 29 '15 at 17:14
Are you using IDA x64? – rev Aug 29 '15 at 17:15
@AcidShout Yes I am using IDA x64 – FreeMind Aug 29 '15 at 17:15
AFAIK you cannot debug a 64 bit application locally with IDA Pro.
You need to use remote debugging.
See this page: https://www.hex-rays.com/products/ida/debugger/#details
and this: https://www.hex-rays.com/products/ida/debugger/cross-win-linux/win32towin64.shtml
0xec
- 6,090
- 3
- 23
- 33
I am win7 x64 - Should I run the IDA on VMware x86 OS and then make remote debugging on my x64 application through VMware? What would the scenario for my situation? – FreeMind Aug 29 '15 at 18:17
@FreeMind You can copy the debugging server
win64_remotex64.exe
to the target machine(x64). Now in the other VM(32/64), run IDA 64, and useattach to remote win64
to debug. – 0xec Aug 29 '15 at 18:23 -
Where is
win64_remotex64.exe
located at? I have checkedC:\Program Files\Windows Kits\8.1\Debuggers\x64
but there is no file over there. – FreeMind Aug 29 '15 at 18:27 -
1@FreeMind
win64_remotex64.exe
is a part of IDA. Check within your IDA installation directory. – 0xec Aug 29 '15 at 18:29
