I am trying to implement the HHL algorithm (for solving $Ax=b$). I am assuming $A$ to be unitary and Hermitian so that I can find the Hamiltonian simulation for it easily. For any $A$ to be Hermitian and unitary, it has to be of form, $$ A = \begin{pmatrix} x & \pm\sqrt{1-x^2}\\ \pm\sqrt{1-x^2} & x\end{pmatrix} $$ I reduced $e^{i\alpha A}$ to following (by using formula $e^{i\theta A} = (\cos\theta)I + i(\sin\theta)A$ where $A^2=I$), but I don't know how to implement it on Qiskit. $$ e^{i\alpha A} = \begin{pmatrix} \cos\alpha+i\sin\alpha\cos\frac{\theta}{2} & i\sin\alpha \sin\frac{\theta}{2} \\ i\sin\alpha \sin\frac{\theta}{2} & \cos\alpha+i\sin\alpha\cos\frac{\theta}{2} \end{pmatrix} .$$ where $\theta = 2\cos^{-1}{x}$. How to construct this gate?
There are plenty of methods that can be used to implement a given unitary matrix.
Only for 1-qubit gates ($2\times 2$ matrix):
- The algorithm described in https://arxiv.org/abs/1212.6253 seems to be the most efficient at the moment. It is restricted to 1-qubit quantum gates ($2\times 2$ unitary matrices) and only decompose in the Clifford + T basis.
- See this answer from @Niel de Beaudrap for other links.
For n-qubit gates ($2^n \times 2^n$ unitary matrices):
- The Solovay-Kitaev algorithm.
- All the Hamiltonian simulation algorithms. See my answer on another question for a list of links about Hamiltonian simulation.
As you specifically mentioned Qiskit, you will probably be interested by this answer that show how to use Qiskit to initialise the $|0^{\otimes n}\rangle$ state to an arbitrary state.
If you give to this procedure the desired output state $$ e^{i\alpha A}|0\rangle = \begin{pmatrix} \cos\alpha+i\sin\alpha\cos\frac{\theta}{2} & i\sin\alpha \sin\frac{\theta}{2} \\ i\sin\alpha \sin\frac{\theta}{2} & \cos\alpha+i\sin\alpha\cos\frac{\theta}{2} \end{pmatrix} \begin{pmatrix}1 \\ 0\end{pmatrix} = \begin{pmatrix} \cos\alpha+i\sin\alpha\cos\frac{\theta}{2} \\ i\sin\alpha \sin\frac{\theta}{2}\end{pmatrix} $$ then the quantum circuit generated by the procedure will implement the unitary $e^{i\alpha A}$.
The issue with this method is that you will need to recompute the unitary for every different value of $\alpha$ you encounter.
- 4,927
- 20
- 58
(Remark: I have corrected a typo in the matrix exponentiation).
Please notice that the matrix has the form:
$$ e^{i\alpha A} = \begin{pmatrix} a & b \\ b & a \end{pmatrix} $$ with $$|a|^2 + |b|^2 = 1$$ Now, please notice that this matrix can be expanded as: $$\begin{pmatrix} a & b \\ b & a \end{pmatrix} = \begin{pmatrix} e^{i \arg(a)} & 0 \\ 0 & e^{i \arg(a)} \end{pmatrix} \begin{pmatrix} |a | & i|b| \\ i|b |& |a| \end{pmatrix} $$ Defining $$ |a| = \cos \phi$$ $$ |b| = \sin \phi$$ Thus we obtain: $$ e^{i\alpha A} = e^{i \arg(a) I_2} e^{i\phi \sigma_x} $$ In short, the result constitutes of an overall phase multiplication and an $R_x$ gate.
Expressed in the question's original variables: $$\arg(a) = \arctan (\tan \alpha \cos \frac{\theta}{2})$$ and $$\phi = \arcsin (\sin \alpha \sin \frac{\theta}{2})$$
- 2,555
- 7
- 10
