Consider a tripartite quantum system with the three subsystems labeled $A, B,$ and $C$. Now take two states $\rho_{AB}$ on the joint system $AB$ and $\rho_{BC}$ on the joint system $BC$. Under what conditions are these compatible with the same global state of $ABC.$
In other words when does a state $\tau_{ABC}$ exist such that $Tr_{C}(\tau_{ABC}) = \rho_{AB}$ and $Tr_A(\tau_{ABC}) = \rho_{BC}.$
A necessary condition for the existence of such a state would be $Tr_A(\rho_{AB}) = Tr_C(\rho_{BC}).$
Is this condition sufficient? If not, are sufficient conditions known?
biryani
  • 966
  • All states $\rho_{ABC}$ have $Tr_{C}(\rho_{ABC})=\rho_{AB}$ and $Tr_{A}(\rho_{ABC})=\rho_{BC}$. I think you need to edit the second line to make your question clearer. – GaussStrife Nov 09 '21 at 15:04
  • The notation is fixed now. Thanks – biryani Nov 09 '21 at 16:17
    We can show the condition is insufficient using an example: Let A, B and C be 2d systems, and both \rho_{AB} and \rho_{BC} equal the maximally entangled state |\phi^+>. Then, your condition is satisfied, however, due to the monogamy of entanglement, there cannot exist a state where both \rho_{AB} and \rho_{BC} is maximally entangled. – Mahathi Vempati Nov 19 '21 at 11:21
