What is the difference between Vlans and subnets? I don't mean the configure or structure
Asked
Active
Viewed 1,103 times
VLANs are an Ethernet concept. Subnets are an IP concept.
A VLAN splits an Ethernet network into multiple logically seperate Ethernet networks.
A subnet defines which hosts a host will try to communicate with directly verses which hosts will need to go via a router. It also defines "network" and "broadcast" addresses.
It is common practice to have a 1:1 mapping between subnets and VLANs but it is perfectly possible to have multiple subnets on the same VLAN. Equally it is possible to use proxy arp to split a subnet between multiple VLANs or even have two VLANs using the same IP subnet for different purposes.
Peter Green
- 13,303
- 2
- 21
- 47
