About a month ago one of my SRX100 started to go into a bootloop for no obvious reason to me.
After some hours, it eventually stopped and booted up the system again (primary) and I was happy that I could create a rescue config. However, I did not have time to copy the configuration to a remote host before this issue started again. The device boots up, give me a few error messages that varies, such as:
SUMMARY INFORMATION BAD
SALVAGE? yes
BLK(S) MISSING IN BIT MAPS
SALVAGE? yes
FREE BLK COUNT(S) WRONG IN SUPERBLK
SALVAGE? yes
Sometimes it also says (but as stated before, it varies):
INCORRECT BLOCK COUNT I=33517 (16 should be 0)
CORRECT? yes
So I started google a bit and found several posts that looked similar and they where all recommended to install a fresh version of JUNOS from a USB or TFTP server. So I did the same. I installed the newest version I could find (junos-12.1X45-D15.5-domestic) using TFTP with the --format option but I am still having the same problem.
Basically, the device is fine and can boot up, I can even log in (the interfaces haven't activated yet though), and after about 50-60 sec it just reboots again, without any messages on the console. Looks like it got a power reset or something.
I've also tried running the nand-mediack.sh utility (just running the script, no options) but it just comes back empty.
So, anyone have a clue of what's going on here? Is there any logs I can look at? Can I transfer my config out of there?
Thanks in advance.
Ryan Foley
  • 5,509
  • 24
  • 43
xeet
  • 173
    Sounds like a bad "disk", but never having opened an SRX100, I don't know what's in it -- 'tho I doubt there's a spinning disk in it. – Ricky Nov 03 '13 at 22:41
  • Yeah, thats what I figured as well. And you are right, there is no spinning disk in it. Heres a picture of its internals: http://andkorn.org/images/posts/2013-05-24-juniper-srx100h-internals2.jpg – xeet Nov 04 '13 at 05:17
  • SRX100 uses FLASH chips... not disks – Remi Letourneau Nov 07 '13 at 18:01
    If you still haven't solved this, is there enough time where the device is up that you could pulls some logs? – Jordan Head Dec 08 '13 at 22:30
Your config is possibly safe (if you care about them you should consider rancid or make manual backups) as it's on a different partition.
If you place the install image on a FAT32 formatted USB key you can reinstall JunOS from there, however you may need to use the reformat option which will wipe any config.
Juniper doc: http://www.trapezenetworks.com/techpubs/en_US/junos12.2/topics/task/installation/security-junos-os-boot-loader-usb-storage-device-srx-series-device-installing.html
LapTop006
  • 1,743
  • 24
