The ethernet IEEE 802.3 standard defines the minimum Ethernet frame size as 64 bytes, and the maximum frame size as 1518 bytes. Why is There a Minimum and Maximum Ethernet Frame size?
For example:
An ethernet frame has a minimum size because anything that is shorter than the 64 byte minimum is interpreted by receiving stations as a collision and is automatically discarded.
But why maximum as 1518?
Ricky
  • 32,147
  • 43
  • 85
j29392
Different frame sizes accommodate different traffic needs. For instance, VoIP traffic is best served by many small datagrams, and a server backup is better served by fewer but larger datagrams.
If you had one fixed frame size, you could end up wasting a lot of network bandwidth by padding for VoIP with larger frame sizes, or you could end up wasting a lot of bandwidth with protocol overhead for server backups with smaller frame sizes.
One size does not fit all.
Edit to answer your changed question:
The sizes go back to the original ethernet medium. The minimum of 64 bytes was the minimum to make sure that a frame completely filled the medium from end-to-end so that the other hosts could detect that the medium is in use. The minimum is too small for some applications, so a maximum needed to be determined..
Your question of why the choice for the maximum size is actually answered in another question: How was the MTU size for ethernet frames calculated as 1500 bytes?
Ron Maupin
  • 99,565
  • 26
  • 120
  • 195
