So I've been follwing the official upgrade guide (posted here and on getmonero.org.)
I have updated my binaries, PGP-verified them. Now my issue is that when I have a monero-wallet-cli
session open, when I run bc_height
, I keep on getting 1546200, and it never changes over time. I made sure monerod
is running in the background.
What could be the source of this issue, and how may I fix it?
EDIT:
I have looked into the monerod
log. Looks like it's looping over the same block over and over again ("Sync data returned a new top block candidate: 1546200 -> 1546107
Maybe this can be a hint into where the problem lies?
Note how the blockheight 1546200 keeps on being repeated throughout the log.
:18.702 [P2P3] INFO global src/cryptonote_protocol/cryptonote_protocol_handler.inl:310 [172.87.222.52:63617 INC] Sync data returned a new top block candidate: 1546200 -> 1546545 [Your node is 345 blocks (0 days) behind]
SYNCHRONIZATION started
2018-04-07 10:55:40.008 [P2P7] INFO global src/cryptonote_protocol/cryptonote_protocol_handler.inl:310 [86.238.48.197:55908 INC] Sync data returned a new top block candidate: 1546200 -> 1546107 [Your node is 93 blocks (0 days) ahead]
2018-04-07 10:56:01.093 [P2P1] INFO global src/cryptonote_protocol/cryptonote_protocol_handler.inl:310 [115.70.158.104:18080 OUT] Sync data returned a new top block candidate: 1546200 -> 1546107 [Your node is 93 blocks (0 days) ahead]
2018-04-07 10:56:05.234 [P2P4] INFO global src/cryptonote_protocol/cryptonote_protocol_handler.inl:310 [5.79.127.3:18080 OUT] Sync data returned a new top block candidate: 1546200 -> 1546107 [Your node is 93 blocks (0 days) ahead]
2018-04-07 11:00:06.245 [P2P8] INFO global src/cryptonote_protocol/cryptonote_protocol_handler.inl:310 [24.72.65.53:45675 INC] Sync data returned a new top block candidate: 1546200 -> 1546601 [Your node is 401 blocks (0 days) behind]
2018-04-07 11:00:12.806 [P2P9] INFO global src/cryptonote_core/blockchain.cpp:1475 ----- BLOCK ADDED AS ALTERNATIVE ON HEIGHT 1546105
PoW: <b3acabff4c6b129a9830433e7b2647d498923b714e2b7879d21b3f0400000000>
difficulty: 99825426467
2018-04-07 11:00:13.327 [P2P9] INFO global src/cryptonote_core/blockchain.cpp:1475 ----- BLOCK ADDED AS ALTERNATIVE ON HEIGHT 1546106
PoW: <3e82477e9f7a3304b9c217d238a41a23ef298f9c6506a596b127e80600000000>
difficulty: 99179807859
2018-04-07 11:00:13.796 [P2P9] INFO global src/cryptonote_core/blockchain.cpp:1475 ----- BLOCK ADDED AS ALTERNATIVE ON HEIGHT 1546107
PoW: <eb6e6dd5b15fe5fa18b923ef7e27dedd0c911882aa32702a04c0ad0000000000>
difficulty: 98591306489
2018-04-07 11:01:56.189 [P2P0] INFO global src/cryptonote_protocol/cryptonote_protocol_handler.inl:310 [83.162.43.154:61616 INC] Sync data returned a new top block candidate: 1546200 -> 1546585 [Your node is 385 blocks (0 days) behind]
TIA!
monero-blockchain-import --pop-blocks 250
to get your chain to before the fork height, so it can choose the right chain when it gets to 1546000. – scoobybejesus Apr 07 '18 at 15:49
