I get these two situations...
If I try to run the wallet gui file with that command, it shows as following:
amnesia@amnesia:~/Persistent/Tor Browser/monero-wallet-gui$ ./monero-wallet-gui ./monero-wallet-gui: error while loading shared libraries: libQt5Quick.so.5: cannot open shared object file: No such file or directory
Also if I try to run from the script provided, I get the following:
./start-gui.sh ./monero-wallet-gui: /usr/lib/i386-linux-gnu/libstdc++.so.6: version GLIBCXX_3.4.21' not found (required by ./monero-wallet-gui) ./monero-wallet-gui: /usr/lib/i386-linux-gnu/libstdc++.so.6: versionGLIBCXX_3.4.21' not found (required by /home/amnesia/Persistent/Tor Browser/monero-wallet-gui/libs/libproxy.so.1)
How to correct these? Thanks in advance (:
Extra: I do have the correct (32 bit) installed and also the latest Tails build.
J Doe XMR
  • 41
You seem to be missing the applicable libraries for the build.
If you go to the Monero github page.
https://github.com/monero-project/monero
and scroll down to: Compiling Monero from Source.
And install the necessary libraries highlighted, that should resolve your issue.
Lurker
  • 473
I believe 64-bit is still a requirement for the GUI client.
Also, TAILS intentionally makes it difficult to install new packages and libraries.
I recently attempted running a miner client which TAILS told me had missing dependencies. Subsequently, I attempted to install the dependencies in the terminal with sudo apt-get install <package-name>, but it produced an error I'd never seen before, something like 'UNIX 13 error ...'.
You might try and see if you are able to install the needed dependencies using a similar command in your terminal in TAILS, something like: sudo apt-get install GLIBCXX_3.4.21.
I would think that the ability to package applications in a portable fashion would improve over time going forward as a result of the 'containerization' trend (a la Docker)...
Hope this helps explain what's (most likely) happening for you at least.
Have you tried the CLI (command-line) Wallet on TAILS yet?
bc1984adam
  • Also: You can consider trying to download any needed dependencies from another system onto a USB, loading them up while in TAILS, and moving them to the specified locations in the Live OS. – bc1984adam Jun 01 '17 at 12:40
  • You will need to make sure you had set an Administrator password during initial pre-boot process. Click on the '+' button to see these options: Additional Settings dialog appears, click on Administration Password. Specify a password of your choice in both the Administration Password and Confirm text boxes then click Add. see: tails tutorial on setting admin password – bc1984adam Mar 09 '18 at 15:48
