I found this site (https://www.ditatompel.com/monero/remote-node) which shows the list of some remote Monero nodes. I would like to connect and be able to use my Monero wallet to send transactions over the testnet network.
When I run
monero-wallet-cli --daemon-address
as suggested in this Stack Question and i insert my wallet , the result is:
[wallet (out of sync)]:
The wallet tells me out_of_sync and I can neither mine nor execute other commands. Can anyone tell me why? Is the node I'm using the problem? Should I create my own node?
jtgrassie
  • 19,111
  • 51
AlexCav
[wallet 9xBEEF]: help refresh
Command usage:
  refresh
Command description:
  Synchronize the transactions and balance.
Yes.
jtgrassie
  • 19,111
  • 51
