You need to know the two limits (in addition to the standard limits like $\lim\limits_{x \to 0}\dfrac{\sin x}{x} = 1$): $$\lim_{x \to 0}\frac{x - \log(1 + x)}{x^{2}} = \frac{1}{2},\,\,\lim_{x \to 0}\frac{x - \sin x}{x^{2}} = 0$$ The first of these limits is bit difficult to handle without L'Hospital's Rule and has been calculated in this answer. The second limit is solved in this answer.
Note that if we put $x = -t$ in the first limit we get $$\lim_{t \to 0}\frac{\log(1 - t) + t}{t^{2}} = -\frac{1}{2}$$ and we will use this form here. We proceed as follows $$\begin{aligned}L &= \lim_{x \to 0}\frac{\log(1 - \sin x) + x}{x^{2}}\\
&= \lim_{x \to 0}\frac{\log(1 - \sin x) + \sin x + x - \sin x}{x^{2}}\\
&= \lim_{x \to 0}\frac{\log(1 - \sin x) + \sin x}{x^{2}} + \lim_{x \to 0}\frac{x - \sin x}{x^{2}}\\
&= \lim_{x \to 0}\frac{\log(1 - \sin x) + \sin x}{\sin^{2}x}\cdot\frac{\sin^{2}x}{x^{2}}\\
&= \lim_{x \to 0}\frac{\log(1 - \sin x) + \sin x}{\sin^{2}x}\\
&= \lim_{t \to 0}\frac{\log(1 - t) + t}{t^{2}}\text{ (putting }t = \sin x)\\
&= -\frac{1}{2}\end{aligned}$$
