Can anyone give me an example of a Topological Vector Space that is not metrizable? I know that the neighborhood base of $0$ needs to be incountable, and all I can construct then is no topological vector space because the algebraic operations (especially multiplication) aren't continous.
Asked
Active
Viewed 481 times
possible duplicate of Prove that some topology is not metrizable – Tomasz Kania Oct 15 '14 at 07:47
@TomekKania I don't think it's a duplicate. There's a difference between proving that some given topology is not metrizable, and coming up with the non-metrizable topology yourself. – Najib Idrissi Oct 15 '14 at 09:08
Take for instance $\mathbb{R}^{\mathbb{R}}$ with the product topology or the weak topology on an infinite-dimensional Banach space. You will find more examples here.
Tomasz Kania
- 16,361
2The product topology on $\Bbb{R}^\Bbb{N}$ is metrizable, in fact the topology is polish. You will have to take uncountable products. – PhoemueX Oct 15 '14 at 07:47
product topology on $R^n$ sounds good. if possible i'd like to stick to a finite dimensional. so the product topology there isn't the same as the topology induced by the common norms? – Bananach Oct 15 '14 at 07:47
oh, okay. that's what I suspeceted. thanks for the examples and the link – Bananach Oct 15 '14 at 07:48
@Bananach: On finite dimensional vector spaces, the product topology is just the "usual" topology, so you will have to take an infinite dimensional example. – PhoemueX Oct 15 '14 at 07:48
@PhoemueX, you need the space to be Hausdorff as seen here. Otherwise any vector space equipped with indiscrete topology is not metrizable. – ChesterX Oct 15 '14 at 07:57
@ChesterX: Sure, thanks :) What I tried to get at was that the product topology of the usual topology on the factors $\Bbb{R}$ is the same as the usual topology on $\Bbb{R}^n$. The general statement is that
every Hausdorff topology on a vector space which makes the vector space operations continuous is the usual topology.
I also ommited the addition concerning the compatibility with the vector space structure before, for simplicity.
– PhoemueX Oct 15 '14 at 08:00 -
my question is fully answered by your examples and terry's theorem 2, thanks for the quick help everyone – Bananach Oct 15 '14 at 08:05
