Prove If LCM(a,b) = c and a|k and b|k then c|k.
I know that c divides a and b if c = Least Common Multiple of a and b.
I also know that c divides all multiples of a and b.
I just am not sure how to go about proving it.
user84413
  • 27,211
Lizzie
  • 211
    It depends on the definition of lowest common multiple. My usual definition (in the natural numbers) is: $m$ is the lowest common multiple of $a$ and $b$ if $a\mid m$, $b\mid m$ and, for all $k$, if $a\mid k$ and $b\mid k$, then $m\mid k$. So your statement doesn't need a proof, because it is part of the definition. Of course one has to prove existence of the lowest common multiple. – egreg Oct 08 '14 at 14:32
  • You write "divides" when you mean "is divisible by". – Junglemath Jun 14 '20 at 22:32
By the Division Algorithm, $k=qc+r$ where $0\le r<c$.
Then $a|k$ and $a|c\implies a|r$, $\;\;$and $\;\;$$b|k$ and $b|c\implies b|r$.
Since $r$ is a common multiple of $a$ and $b$ with $r<c$, $r=0$.
user84413
  • 27,211
I will use this notation: if $p$ is any prime and $r\geq 2$ is a natural number, then $\mu_p(r)$ is the power that $p$ is raised to in the prime factorization of $r$. For example, $\mu_5(150)=2$ and $\mu_2(21)=0$.
We shall show that for each $p^n$ that divides $c$, (where $p$ is a prime and $n$ is a natural number) $p^n$ also divides $k$.
Indeed, if $p^n$ divides $c$, then $\mu_p(c)\geq n$, but $\mu_p(c)=\max\{\mu_p(a),\mu_p(b)\}$. Thus, $p^n$ divides $a$ or $b$. Since $a$ and $b$ divide $k$, $p^n$ also divides $k$.
Now, we have $\mu_p(k)\geq\mu_p(c)$, and this is true for every prime $p$. This means that $c$ divides $k$.
ajotatxe
  • 65,084
