I have a cuboid in 3D space, it is not regular at all. I do have the coordinates of its 8 vertices and my problem is how to determine a given point coordinate is inside or outside this cuboid.
I have so far though that if I can calculate the distance of the point to each of the 6 side planes then I can find out the answer. Assume I can calculate for each side the plane formula with the normal pointing out of the cuboid, then for the point to be inside all distances must be negative, right? If one of the 6 distances is positive then the point is on the outside.
Is this the shortest and simplest approach?
