example , $$ a_n=6a_{n-1}-9a_{n-2},a_0=0,a_1=1 $$ what is the $a_n$?
In fact, I want to know there are any way to deal with this situation.
We assume that you are dealing with linear homogeneous recurrences with constant coefficients.
When the characteristic equation has degree $2$ and a double root $r$, the general solution is $Ar^n +Bnr^n$.
If the equation has degree $3$, a double root $r$ and a single root $s$, use $Ar^n+Bnr^n+Cs^n$.
If there is a triple root $r$, use $Ar^n+Bnr^n+Cn^2r^n$.
And so on.
Remark: The situation is analogous to what we do with linear homogeneous differential equations with constant coefficients when the characteristic equation has multiple roots.
Here is a fun way to get to the answer:
Suppose we have a recursion $A_n = c_1A_{n-1} + c_2A_{n-2} + \dots + c_kA_{n-k}$. When you are doing the usual approach, you are looking for geometric sequences that satisfy this recursion, and you end up looking for nonzero roots $r$ of:
$$x^n = c_1x^{n-1} + c_2x^{n-2} + \dots + c_k x^{n-k}$$
Now remember that when we have a double root of a polynomial, then it is also a root of the derivative of that polynomial. So if we are in that case and $r$ is a double root of this let's differentiate the above equation, and then multiply by $x$ to keep it looking nice:
$$nx^n = c_1(n-1)x^{n-1} + c_2(n-2)x^{n-2} + \dots + c_k(n-k) x^{n-k}$$
We know $r$ must still must be a root of this, so we plug in $r$ and look carefully this says that the sequence $A_n = nr^n$ satisfies our original recursion. Hooray!
If $r$ is a root of multiplicity more than 2, then we can differentiate the equation more times to get more sequences of the form $A_n = n^kr^n$ for $k$ less than the multiplicity of $r$.
I know another way to get at this using linear algebra that I think is a bit more enlightening as to why these are the answers, and why you never get anything else, but in my opinion this differentiation trick is pretty slick.
A bare-hands method would be as follows:
$$a_n - 3 a_{n-1} = 3 ( a_{n-1} - 3 a_{n-2} )$$
$$a_n - 3 a_{n-1} = 3^{n-1} ( a_1 - 3 a_0 )$$
$$\sum_{k=1}^n 3^{n-k} ( a_k - 3 a_{k-1} ) = \sum_{k=1}^n 3^{n-k} \left( 3^{k-1} ( a_1 - 3 a_0 ) \right)$$
$$\sum_{k=1}^n 3^{n-k} a_k - 3^{n-(k-1)} a_{k-1} = \sum_{k=1}^n 3^{n-1} ( a_1 - 3 a_0 )$$
$$a_n - 3^n a_0 = n 3^{n-1} ( a_1 - 3 a_0 )$$
The constants were obtained from the factorization of the quadratic.
Note that the above method works regardless of whether the roots are repeated, although the last step will differ.
