How to solve $\displaystyle x=\sqrt{4+\sqrt{4-\sqrt{4+\sqrt{4-x}}}}$ for $x$?
I tried this way:
Let
$$f(x)=\sqrt{4+\sqrt{4-x}}$$
So, $x=f^2(x)=f^{2n}(x)$ where $n\in\mathbb{N}$. Then, I tried to prove that $f^k(x)=f^{k+1}(x)$ for any $k\in\mathbb{N}$, but I cannot find any easy way to prove this. If I succeed to prove this, I can write
$$x=\sqrt{4+\sqrt{4-x}}$$
because for $k=0$ I have $f^0(x)=f^1(x)$, but then it will be hard to solve $x=\sqrt{4+\sqrt{4-x}}$.
My question is: how to prove that $f^k(x)=f^{k+1}(x)$ and how to solve $x=\sqrt{4+\sqrt{4-x}}$? If you have any easier method, post your solution.
It's not possible to prove $f^k(x) = f^{k+1}(x)$ since it would lead to say $f(x)=x$ which is not true – Petite Etincelle Aug 15 '14 at 12:36
1Hint: To solve your equation $x=\sqrt{4+\sqrt{4-x}}$ notice that it can be written and then factorized as $(x^2-4)^2-4+x = (x^2-x-3) (x^2+x-4) = 0$ – Winther Aug 15 '14 at 12:39
@Liu Gang. Solution is $\displaystyle\frac{1+\sqrt{13}}2$ and you can easy find that $x=f(x)=f^2(x)$. – Aug 15 '14 at 12:41
@Mathematician171 Ah sorry, I misread it. I thought it was for any $x$ – Petite Etincelle Aug 15 '14 at 12:44
It's easy to prove $f^k = f^{k+1} = x$ by using induction. The case $k=2$ is simple as $f(f(x)) = f(x) = x$. Now assume that the formula applies for $k=n$ then $f^{n+1} = f(f^{n}) = f(x) = x$ and the formula applies for $k=n+1$. By induction we have $f^k = f^{k+1} = x$ for all $k\in\mathbb{N}$. – Winther Aug 15 '14 at 12:57
@Winther. How it is trivial to prove? Can you explain how $f(f^n(x))=f(x)$? – Aug 15 '14 at 13:04
Do you know about mathematical induction? We assume that $f^n(x) = x$ then use this to show that $f^{n+1}(x) = f(f^n(x)) = f(x) = x$ (since $f^n(x)=x$ we can replace the argument $f^n(x)$ in $f(f^n(x))$ with $x$). Thus if the statement is true for $n$ then its true for $n+1$. Since its true for $n=1$ it's then true for $n=1+1=2$ and then for $n=2+1=3$ and so on. The principle of induction then tells us that its then true for all $n\in\mathbb{N}$. – Winther Aug 15 '14 at 13:10
@Winther. Yes, I know about mathematical induction, but we do not have that $f(x)=x$ or $f^3(x)=x$, we have that $f^{2n}(x)=x$ (only even number of $f$-s). Question is how to prove that $f^n(x)=x$ (any natural number of $f$-s). – Aug 15 '14 at 13:20
$\displaystyle x=\sqrt{4+\sqrt{4-\sqrt{4+\sqrt{4-x}}}}$, the replace $x$ at RHS by the same equaility, we get $$x=\sqrt{4+\sqrt{4-\sqrt{4+\sqrt{4-\sqrt{4+\sqrt{4-\sqrt{4+\sqrt{4-x}}}}}}}}$$.
Continue in this way then we know that $x$ is equal to the limit(provided it exists) of $$\sqrt{4+\sqrt{4-\sqrt{4+\sqrt{4-\sqrt{4+\sqrt{4-\sqrt{4+\sqrt{4-\cdots}}}}}}}}$$.
To compute the limit, say $l$, we have $l = \sqrt{4+\sqrt{4-l}}$, which is not hard to solve.
As for existence of the limit, remark that if $a_1(x) = \sqrt{4+\sqrt{4-x}}$ and $a_{n+1}(x) = a_n(a_1(x))$, then $|a_n(x)-a_n(y)| \leq |a_n(4) - a_n(0)|$(since $a_n(x)$ is either increasing or decreasing), which tends to $0$ by repeating using $\sqrt{x}-\sqrt{y} =\frac{x-y}{\sqrt{x}+\sqrt{y}}$. So $a_n(x)$ is Cauchy(since $a_{n+k}(x)= a_n(y)$ for some $y$) and the limit exists
- 14,767
First asume that we have a solution $x_0$ to $$f(f(x)) = x$$ then, as $f(y)\geq 2 \ \ \forall y \in (-\infty,4]$, we have $x_0\geq 2$, so we can restrict to $[2,4]$.Also, if $x \in [2,4]$, $$ 4-x\leq 2$$ $$ \sqrt{4-x}\leq \sqrt{2}$$ $$ 4 + \sqrt{4-x}\leq 4 + \sqrt{2}$$ $$ \sqrt{4 + \sqrt{4-x}}\leq\sqrt{ 4 + \sqrt{2}}=:\alpha<4$$ so $x_0\in [2,\alpha]$ and even more the function $$f:[2,\alpha]\rightarrow [2,\alpha]$$ is well defined. so if a solution to $f(f(x)) = x$ exists, it have to be in $[2,\alpha]$. Now we have that $$f'(x) = \frac{-1}{2\sqrt{4 + \sqrt{4-x}}\sqrt{4-x}}$$ $$|f'(x)| \leq \frac{1}{2\sqrt{4 + \sqrt{4-\alpha}}\sqrt{4-\alpha}}$$ and you can verify that $$\frac{1}{2\sqrt{4 + \sqrt{4-\alpha}}\sqrt{4-\alpha}}\approx 0.168 <1$$ So $f$ is a strict contraction and so it is $f^2$.By Banach fixed point theorem $f^2$ have one and only one fixed point $x_0$ in $[2,\alpha]$ $$f(f(x_0)) = x_0$$ $$f(f(f(x_0))) = f(x_0)$$ if we call $x_1 = f(x_0)$ $$f(f(x_1)) = x_1$$ so $x_1$ is also a fixed point of $f^2$ hence , $x_0 = x_1 = f(x_0)$ ($f^2$ have only one fixed point).
To summarise: the equation $f(f(x)) = x$ have only one solution and is also a solution to $f(x) = x$.
- 2,451
