Prove using esplion-delta.
$$\lim_{x \to 1-} \left[\frac{1}{x}\right]=1$$
My prove :
All $\varepsilon>0$ exist $\delta>0$ so all x that appiles $1-\delta<x<1$ appiles $\left|\left[\frac{1}{x}\right]-1\right|<\varepsilon$
So for $\delta=1$ exist $\varepsilon>0$ .
Therefore :
$$1-\delta<x<1$$ $$1-1<x<1$$ $$0<x<1$$
As well :
$$0<\frac{1}{x}<1$$
Therefore :
$$\left|\left[\frac{1}{x}\right]-1\right|=|0-1|=1<\varepsilon$$
I'm not sure I did it correctly, Since I didn't come up with $\delta$ that depends on $\varepsilon$ could somebody explain? any help will be appreciated.
beep-boop
  • 11,595
JaVaPG
  • 2,716
First of all, if $0 < x < 1$, then you have $1 < \frac{1}{x} < \infty$, not $0 < \frac{1}{x} < 1$.
Second, you don't necessarily have to find a $\delta$ that depends on $\epsilon$. The $\epsilon$-$\delta$ definition of the limit requires that for any $\epsilon > 0$ you find a $\delta > 0$. Usually, the value of $\delta$ will change with $\epsilon$, but not always.
Notice that if $\frac{1}{2} < x < 1$, then $1 < \frac{1}{x} < 2$. Therefore, $\left[\frac{1}{x}\right] = 1$ for all $x$ such that $\tfrac{1}{2} < x < 1$.
Use that to find a $\delta$ such that $\left|\left[\frac{1}{x}\right]-1\right| < \epsilon$ for all $x$ such that $1-\delta < x < 1$.
JimmyK4542
  • 54,331
  • If we choose $\delta=\frac{1}{2}$ therefore $$|[\frac{1}{x}]-1=|1-1|=0<\varepsilon$$, If I understood the concept right, since $\varepsilon$ doesn't rely on $\delta$ it means for for any $\varepsilon>0$ any $\delta>0$ will be fine? – JaVaPG Aug 13 '14 at 23:34
  • Not quite. What you have shown is that for any $\epsilon > 0$, $\delta = \frac{1}{2}$ works. – JimmyK4542 Aug 13 '14 at 23:35
  • Other question if I may, In case $\delta=1$ the problem cannot be solved? right? – JaVaPG Aug 13 '14 at 23:39
  • You can't use $\delta = 1$ to solve the problem. But that doesn't matter. For any $\epsilon > 0$ you get to choose the $\delta > 0$. So for this problem, don't pick $\delta = 1$. – JimmyK4542 Aug 13 '14 at 23:40
