Are there any tricks with raising an element from a finite field to power. For example let $ a \in GF(p^n)$ and I want to compute $a^m$ for some $m \in \mathbb{Z}$. Is there a nice trick to do this fast?
Many thanks.
Many thanks.
One common trick, which requires $O(\log_2 m)$ multiplications, is to use the following algorithm:
For example, to calculate $a^{1000}$, you calculate the following, using one multiplication each: $a^2, a^3, a^6, a^7, a^{14}, a^{15}, a^{30}, a^{31}, a^{62}, a^{124}, a^{125}, a^{250}, a^{500}, a^{1000}$, for a total of 14 multiplications. To calculate $a^{1000000}$ would require only about twice as many multiplications.
This is not optimal, but it is fast enough that people often don't bother with anything faster.
In some representations of the field $\mathbb{F}_{p^n}$, computing $\alpha^p$ -- called the Frobenius automorphism -- is very easy. For example, if you write elements via their coordinates with respect to a normal basis over $\mathbb{F}_p$ (i.e. a basis of the form $\{ \beta, \beta^p, \beta^{p^2}, \ldots, \beta^{p^{n-1}}\}$), then the Frobenius automorphism is just cyclically permuting the coordinates.
If it's not, it's still a $\mathbb{F}_p$-linear transformation, and so in many other representations, you can simply compute the matrix representing this linear transformation, and so you can raise to the $p$-th power simply by multiplying by this matrix. (or maybe your representation gives a faster way to do this) And by taking powers of this matrix, you can thus compute $\alpha^{p^k}$ efficiently.
If you're trying to compute $\alpha^b$ and $b \geq p$, the above gives you a short cut, similar to the usual "square and multiply" algorithms.
In some other representations, your problem is trivial: e.g. if you store a finite field element as its discrete logarithm, all you have to do to compute $\alpha^k$ is to compute a multiplication by $k$, modulo $p^n - 1$.
