Does the following integral have a closed form solution? $$ \int_{y_1}^{y_2} \exp\left(\, -\alpha x\,\right)\, x \sqrt{1-x^2}{\rm d}x $$ $$ 0< y_1 < 1 $$ $$ 0< y_2 < 1 $$
Or is there an approximation which works for large $\alpha$?
Roy
  • 343
    It seems WA does not find any closed form... – Dmoreno Jul 31 '14 at 09:44
    One thing point out is that, if one takes $x=\sin \theta$, then the integral is $$\int_{0}^{\sin y}e^{-\alpha \cos \theta}\cos^2\theta \sin\theta,d\theta$$ which can be obtained from $\int_0^{\sin y} e^{-\alpha \cos\theta},d\theta$ by partial derivatives wrt $\alpha$. Problem is that this integral is simpler in appearance, it doesn't seem to have a closed form either... – Semiclassical Jul 31 '14 at 13:21
    I have to ask where are all these integrals coming from? All very similar (granted very different solutions) but I must know :)? – Chinny84 Aug 04 '14 at 21:37
  • :) This is related to my research which is taking me a lot of time. – Roy Aug 04 '14 at 21:49
  • You could also do that integration by means of the Laplace Transform. – enthu Aug 12 '14 at 20:02
In terms of elementary functions ? No, it does not. However, for $y=\pm1$ a closed form does exist, but in terms of the special functions Bessel I and Struve L.
Lucian
  • 48,334
  • 83
  • 154
    One lesson from Lucian's answer: definite integrals are often more well-studied i.e. have special function representations. Indefinite integrals, if they can't be explicitly integrated, are harder to deal with. @hesam – Semiclassical Jul 31 '14 at 14:11
  • Do you know the expression when y=1? – Roy Aug 01 '14 at 18:49
    $I(\pm1)=\dfrac\pi a\bigg[\dfrac{L_0(a)\mp I_2(a)}2-\dfrac{L_1(a)}a\bigg]$. – Lucian Aug 01 '14 at 18:56
This could help here. $$ \int^{y_2}_{y_1}\mathrm{e}^{-\alpha x}x\sqrt{1-x^2}dx = -\frac{d}{d\alpha}\int\mathrm{e}^{-\alpha x}\sqrt{1-x^2}dx $$ using $x = \cos u$
then
$$ \int^{y_2}_{y_1}\mathrm{e}^{-\alpha x}x\sqrt{1-x^2}dx = -\frac{d}{d\alpha}\int_{\cos^{-1}y_1}^{\cos^{-1}y_2}\mathrm{e}^{-\alpha \cos u}\sin^2 u du $$ here the last bit was edited due to @semiclassical keen eye :). now using $$-\sin^2 u = \cos^2 u - 1$$
we find $$ \frac{d}{d\alpha}\int_{\cos^{-1}y_1}^{\cos^{-1}y_2}\mathrm{e}^{-\alpha \cos u}\left[\cos^2 u -1\right]du = \frac{d}{d\alpha}\left[\frac{d^2}{d\alpha^2}-1\right]\int_{\cos^{-1}y_1}^{\cos^{-1}y_2}\mathrm{e}^{-\alpha \cos u}du $$
$\textbf{update}$ For the special case of $$ \begin{eqnarray} \cos^{-1}y_1 &=& \pi/2,\\ \cos^{-1}y_2 &=& 0. \end{eqnarray} $$ which corresponds to choosing $(y_1,y_2) = (0,1)$ we obtain $$ \int^{0}_{\pi/2}\mathrm{e}^{-\alpha \cos u}du = -\int_{0}^{\pi/2}\mathrm{e}^{-\alpha \cos u}du = -\frac{\pi}{2}\left[I_0(\alpha) - L_0(\alpha)\right] $$
thus $$ \frac{d}{d\alpha}\left[\frac{d^2}{d\alpha^2}-1\right]\int_{\cos^{-1}y_1}^{\cos^{-1}y_2}\mathrm{e}^{-\alpha \cos u}du =\frac{d}{d\alpha}\left[\frac{d^2}{d\alpha^2}-1\right]\left(\frac{\pi}{2}\left[I_0(\alpha) - L_0(\alpha)\right]\right) $$
$$ \begin{eqnarray} \frac{d}{d\alpha}\left[\frac{d^2}{d\alpha^2}-1\right]I_{0}(\alpha) &=& \frac{d^2}{d\alpha^2}I_{1}(\alpha) - I_{1}(\alpha)\\ &=& \frac{d}{d\alpha}\left[\frac{1}{\alpha}I_1(\alpha)+I_2(\alpha)\right] -I_1(\alpha)\\ &=& I_3(\alpha) +\frac{3}{\alpha}I_2(\alpha)- I_{1}(\alpha) \end{eqnarray} $$ and $$ \begin{eqnarray} \frac{d}{d\alpha}\left[\frac{d^2}{d\alpha^2}-1\right]L_{0}(\alpha) &=& \left[\frac{d^2}{d\alpha^2} - 1\right]\left(\frac{1}{2}\left[L_{-1}(\alpha) +L_1(\alpha) + \frac{1}{\sqrt{\pi}\Gamma\left(\frac{3}{2}\right)}\right]\right)\\ &=& \left[\frac{d^2}{d\alpha^2}-1\right]g(\alpha) \end{eqnarray} $$ $$ g'(\alpha) = \frac{1}{4}\left[L_{-2}(\alpha)+2L_0(\alpha) +L_2(\alpha) + \frac{2\alpha^{-1}}{\sqrt{\pi}\Gamma\left(\frac{1}{2}\right)}+\frac{\alpha}{2\sqrt{\pi}\Gamma\left(\frac{5}{2}\right)}\right],\\ g''(\alpha) = \frac{1}{8}\left[L_{-3}(\alpha) + 3L_{-1}(\alpha) + 3L_{1}(\alpha)+L_{3}(\alpha) + \frac{4\alpha^{-2}}{\sqrt{\pi}\Gamma\left(\frac{-1}{2}\right)} +\frac{2}{\sqrt{\pi}\Gamma\left(\frac{3}{2}\right)}+\frac{2^{-2}\alpha^2}{\sqrt{\pi}\Gamma\left(\frac{7}{2}\right)}\right] $$
Thus for this special case $$ \int^{1}_{0}\mathrm{e}^{-\alpha x}x\sqrt{1-x^2}dx =\\ -\frac{\pi}{2}\left[I_3(\alpha) +\frac{3}{\alpha}I_2(\alpha)- I_{1}(\alpha)-\frac{1}{8}\left[L_{-3}(\alpha) - L_{-1}(\alpha) - L_{1}(\alpha)+L_{3}(\alpha) + \frac{4\alpha^{-2}}{\sqrt{\pi}\Gamma\left(\frac{-1}{2}\right)} -\frac{2}{\sqrt{\pi}\Gamma\left(\frac{3}{2}\right)}+\frac{2^{-2}\alpha^2}{\sqrt{\pi}\Gamma\left(\frac{7}{2}\right)}\right]\right] $$ and subbing in for $\Gamma$'s we find $$ -\frac{\pi}{2}\left[I_3(\alpha) +\frac{3}{\alpha}I_2(\alpha)- I_{1}(\alpha)-\frac{1}{8}\left[L_{-3}(\alpha) - L_{-1}(\alpha) - L_{1}(\alpha)+L_{3}(\alpha) -\frac{2\alpha^{-2}}{\pi} -\frac{8}{3\pi}+\frac{2\alpha^2}{15\pi}\right]\right] $$
ps. keep asking questions, hopefully I have not made another silly mistake.
Chinny84
  • 14,186
  • 22
  • Very nice, I think you are close to solution. – Roy Aug 04 '14 at 23:38
    Shouldn't $\sqrt{1-x^2},dx=\sin u , d(\cos u)=\sin^2 u , du$? (I noticed because it seemed too simple based upon my similar comment above.) – Semiclassical Aug 05 '14 at 00:18
    @Semiclassical yes you are totally right :)! I will edit accordingly. – Chinny84 Aug 05 '14 at 04:26
    It's a bit frustrating that $\int e^{-\alpha \cos \theta},d\theta$ isn't a nicer object. – Semiclassical Aug 05 '14 at 10:48
    @Semiclassical you telling me!! It is relative nice just on its own, but taking the derivatives has bound to create some error in the manipulation (3pages with mistakes included ha). But it troubles me that integrating over a different interval doesn't exist.. – Chinny84 Aug 05 '14 at 11:03
It seems there is a closed form but I have not worked on it yet. However you can have this nice approximation for large $\alpha$
$$ I = \int_{0}^{y} x\sqrt{1-x^2} e^{-\alpha x}dx\sim_{\alpha \sim \infty} \frac{1}{\alpha^2}- {\frac { \left( \alpha\,y+1 \right) {{\rm e}^{ -\alpha\,y}}}{{\alpha}^{2}}}.$$
You can use Laplace's method. See my answer where I laid out the basic idea behind it. Note that you can better approximations if you want. Here is a special case for $\alpha=100, y=1$
$$ 0.00009997,\\ 0.0001000 . $$
which they correspond to evaluating the integral and the approximation respectively.
Hint:
$\int_{y_1}^{y_2}e^{-\alpha x}x\sqrt{1-x^2}~dx$
$=\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}e^{-\alpha\sin x}\sin x\sqrt{1-\sin^2x}~d(\sin x)$
$=\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}e^{-\alpha\sin x}\sin x\cos^2x~dx$
$=\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}e^{-\alpha\sin x}\sin x(1-\sin^2x)~dx$
$=\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}e^{-\alpha\sin x}\sin x~dx-\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}e^{-\alpha\sin x}\sin^3x~dx$
$=\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}\sum\limits_{n=0}^\infty\dfrac{\alpha^{2n}\sin^{2n+1}x}{(2n)!}dx-\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}\sum\limits_{n=0}^\infty\dfrac{\alpha^{2n+1}\sin^{2n+2}x}{(2n+1)!}dx-\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}\sum\limits_{n=0}^\infty\dfrac{\alpha^{2n}\sin^{2n+3}x}{(2n)!}dx+\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}\sum\limits_{n=0}^\infty\dfrac{\alpha^{2n+1}\sin^{2n+4}x}{(2n+1)!}dx$
For $n$ is any non-negative integer,
$\int\sin^{2n+2}x~dx=\dfrac{(2n+2)!x}{4^{n+1}((n+1)!)^2}-\sum\limits_{k=0}^n\dfrac{(2n+2)!(k!)^2\sin^{2k+1}x\cos x}{4^{n-k+1}((n+1)!)^2(2k+1)!}+C$
This result can be done by successive integration by parts.
Similarly, $\int\sin^{2n+4}x~dx=\dfrac{(2n+4)!x}{4^{n+2}((n+2)!)^2}-\sum\limits_{k=0}^{n+1}\dfrac{(2n+4)!(k!)^2\sin^{2k+1}x\cos x}{4^{n-k+2}((n+2)!)^2(2k+1)!}+C$
$\int\sin^{2n+1}x~dx$
$=-\int\sin^{2n}x~d(\cos x)$
$=-\int(1-\cos^2x)^n~d(\cos x)$
$=-\int\sum\limits_{k=0}^nC_k^n(-1)^k\cos^{2k}x~d(\cos x)$
$=\sum\limits_{k=0}^n\dfrac{(-1)^{k+1}n!\cos^{2k+1}x}{k!(n-k)!(2k+1)}+C$
Similarly, $\int\sin^{2n+3}x~dx=\sum\limits_{k=0}^{n+1}\dfrac{(-1)^{k+1}(n+1)!\cos^{2k+1}x}{k!(n-k+1)!(2k+1)}+C$
$\therefore\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}\sum\limits_{n=0}^\infty\dfrac{\alpha^{2n}\sin^{2n+1}x}{(2n)!}dx-\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}\sum\limits_{n=0}^\infty\dfrac{\alpha^{2n+1}\sin^{2n+2}x}{(2n+1)!}dx-\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}\sum\limits_{n=0}^\infty\dfrac{\alpha^{2n}\sin^{2n+3}x}{(2n)!}dx+\int_{\sin^{-1}y_1}^{\sin^{-1}y_2}\sum\limits_{n=0}^\infty\dfrac{\alpha^{2n+1}\sin^{2n+4}x}{(2n+1)!}dx$
$=\left[\sum\limits_{n=0}^\infty\sum\limits_{k=0}^n\dfrac{(-1)^{k+1}n!\alpha^{2n}\cos^{2k+1}x}{(2n)!k!(n-k)!(2k+1)}\right]_{\sin^{-1}y_1}^{\sin^{-1}y_2}-\left[\sum\limits_{n=0}^\infty\dfrac{\alpha^{2n+1}x}{2^{2n+1}n!(n+1)!}-\sum\limits_{n=0}^\infty\sum\limits_{k=0}^n\dfrac{(k!)^2\alpha^{2n+1}\sin^{2k+1}x\cos x}{2^{2n-2k+1}n!(n+1)!(2k+1)!}\right]_{\sin^{-1}y_1}^{\sin^{-1}y_2}-\left[\sum\limits_{n=0}^\infty\sum\limits_{k=0}^{n+1}\dfrac{(-1)^{k+1}(n+1)!\alpha^{2n}\cos^{2k+1}x}{(2n)!k!(n-k+1)!(2k+1)}\right]_{\sin^{-1}y_1}^{\sin^{-1}y_2}+\left[\sum\limits_{n=0}^\infty\dfrac{(2n+3)\alpha^{2n+1}x}{4^{n+1}n!(n+2)!}-\sum\limits_{n=0}^\infty\sum\limits_{k=0}^{n+1}\dfrac{(2n+3)(k!)^2\alpha^{2n+1}\sin^{2k+1}x\cos x}{4^{n-k+1}n!(n+2)!(2k+1)!}\right]_{\sin^{-1}y_1}^{\sin^{-1}y_2}$
$=\sum\limits_{n=0}^\infty\sum\limits_{k=0}^n\dfrac{(-1)^{k+1}n!\alpha^{2n}\left((1-y_2^2)^{k+\frac{1}{2}}-(1-y_1^2)^{k+\frac{1}{2}}\right)}{(2n)!k!(n-k)!(2k+1)}-\sum\limits_{n=0}^\infty\dfrac{\alpha^{2n+1}(\sin^{-1}y_2-\sin^{-1}y_1)}{2^{2n+1}n!(n+1)!}+\sum\limits_{n=0}^\infty\sum\limits_{k=0}^n\dfrac{(k!)^2\alpha^{2n+1}\left(y_2^{2k+1}\sqrt{1-y_2^2}-y_1^{2k+1}\sqrt{1-y_1^2}\right)}{2^{2n-2k+1}n!(n+1)!(2k+1)!}-\sum\limits_{n=0}^\infty\sum\limits_{k=0}^{n+1}\dfrac{(-1)^{k+1}(n+1)!\alpha^{2n}\left((1-y_2^2)^{k+\frac{1}{2}}-(1-y_1^2)^{k+\frac{1}{2}}\right)}{(2n)!k!(n-k+1)!(2k+1)}+\sum\limits_{n=0}^\infty\dfrac{(2n+3)\alpha^{2n+1}(\sin^{-1}y_2-\sin^{-1}y_1)}{4^{n+1}n!(n+2)!}-\sum\limits_{n=0}^\infty\sum\limits_{k=0}^{n+1}\dfrac{(2n+3)(k!)^2\alpha^{2n+1}\left(y_2^{2k+1}\sqrt{1-y_2^2}-y_1^{2k+1}\sqrt{1-y_1^2}\right)}{4^{n-k+1}n!(n+2)!(2k+1)!}$
Harry Peter
  • 7,819
