I just started to learn a little bit of fourier analysis in solving PDEs. I want to find a solution $u(x,t)$ to $u_t+u_{xxxx}+u_{xx}=0$.
My attempt: Applying the fourier transform to both sides gives $\frac {d}{dt}\hat u(\omega,t)+(i\omega)^4\hat u(\omega,t)+(i\omega)^2\hat u(\omega,t)$
$\implies \frac {d}{dt}\hat u(\omega,t)=(\omega^2-\omega^4)\hat u(\omega,t)$
This is a first order, autonomous ODE in $\hat u(x,t)$. With integrating factor $e^{\int (\omega^4-\omega^2)d\omega}$, we have $\frac {d}{d\omega}(e^{1/5\omega^5-1/3\omega^3}\hat u(\omega,t))=0$
$\implies e^{1/5\omega^5-1/3\omega^3}\hat u(\omega,t)=C$
$\implies \hat u(\omega,t)=Ce^{1/3\omega^3-1/5\omega^5}$
Does this look alright so far? If so, I'm not sure how I should proceed, as I couldn't find the inverse transform of $e^{1/3\omega^3-1/5\omega^5}$ in any tables.
