Find all value of $\alpha$ such that $\lim\limits_{x\rightarrow +\infty}\left(\frac{\Gamma(x+\alpha)}{\Gamma(x)}-x^{\alpha}\right)=0$. (note: $\alpha$ is a constant with respect to $x$)
By restricting to just the integer case ($\Gamma$ reduce to factorial) it is suggestive that $\alpha\leq 1$ is the answer. I am having trouble upgrading this to the full $\Gamma$, as I don't really know much about this function.
My attempt:
EDIT: now I kinda solved it, but I'm looking for alternative method that are simpler and more accessible. My current solution is as follow:
Case $\alpha<0$: using Stirling's approximation (such as shown here: Quotient of gamma functions?) to show $\lim\limits_{x\rightarrow +\infty}\frac{\Gamma(x+\alpha)}{\Gamma(x)}=0$. Easily show that $\lim\limits_{x\rightarrow +\infty}x^{\alpha}=0$.
Case $\alpha=0$: direct calculation.
Case $0<\alpha<1$: apply Gautschi's inequality found here: How do you prove Gautschi's inequality for the gamma function?. After some substitution we can write it as $(x+\alpha-1)^{\alpha}<\frac{\Gamma(x+\alpha)}{\Gamma(x)}<(x+\alpha)^{\alpha}$ with $0<\alpha<1$. Then show that $\lim\limits_{x\rightarrow\infty}((x+\alpha)^{\alpha}-(x+\alpha-1)^{\alpha})$ using mean value theorem: $(x+\alpha)^{\alpha}-(x+\alpha-1)^{\alpha}$ is the derivative of $x^{\alpha}$ at some point in $(x+\alpha-1,x+\alpha)$, which go to $0$. Then squeeze in.
Case $\alpha=1$: use the functional equation $\Gamma(x+1)=x\Gamma(x)$.
Case $\alpha>1$: the case $\alpha$ is integer is trivial: simply restrict domain to integer $x$ and rewrite as factorial. Otherwise first rewrite $\frac{\Gamma(x+\alpha)}{\Gamma(x)}=(x+\beta)(x+\beta+1)\ldots(x+\alpha-1)\frac{\Gamma(x+\beta)}{\Gamma(x)}$ where $0<\beta=\alpha-[\alpha]<1$ (the bracket is floor). Then use Gautschi's inequality to get $(x+\beta)(x+\beta+1)\ldots(x+\alpha-1)\frac{\Gamma(x+\beta)}{\Gamma(x)}>(x+\beta)(x+\beta+1)\ldots(x+\alpha-1)(x+\beta-1)^{\beta}$. Now we can show $\lim\limits_{x\rightarrow +\infty}x^{\alpha}-x^{[\alpha]}(x+\beta-1)^{\beta}=\lim\limits_{x\rightarrow +\infty}\frac{x^{\beta}-(x+\beta-1)^{\beta}}{x^{[\alpha]}}=0$ using L'Hospital. Hence the problem reduced to showing $(x+\beta)(x+\beta+1)\ldots(x+\alpha-1)(x+\beta-1)^{\beta}-x^{[\alpha]}(x+\beta-1)^{\beta}$ go to infinity. Since $(x+\beta-1)^{\beta}$ go to infinity, we just need to show $(x+\beta)(x+\beta+1)\ldots(x+\alpha-1)-x^{[\alpha]}$ stay away from $0$, which is simply just expanding out the term. This show that none of the $\alpha>1$ work.
However, this proof is awfully complicated, and relying on more obscure results. And it does not intuitively showed why the cut off point is at $\alpha=1$. I am looking for a better proof.
Thank you for your help.
Gina
  • 5,338
  • Can $\alpha$ depend on $x$ or is it constant with respect to $x$? – Antonio Vargas Jul 04 '14 at 14:36
  • @AntonioVargas: it is constant with respect to $x$. – Gina Jul 04 '14 at 14:39
  • Then Claude's approach is correct, no uniformity is necessary. However, there is an error somewhere in his calculation, so I'll write another answer going through the details. – Antonio Vargas Jul 04 '14 at 16:40
  • @AntonioVargas: ah sorry I use terminology from my physics teacher, so it might be a big confusing. But if $f$ is use to approximate $g$, my teacher will say that it is order of magnitude approximation if $\lim\frac{f}{g}=1$, and uniform approximation if $\lim(f-g)=0$. Which is why I highly doubt that Stirling approximation method can work, as it basically throw away information. One way to see this is to notice that using Stirling, one can "prove" that all $\alpha$ work, but it's easy to show that $\alpha=2$ does not. – Gina Jul 04 '14 at 16:57
Let $\alpha \in \mathbb R$ be fixed. We'll assume that $\alpha \neq 0$ and $\alpha \neq 1$ --- in these cases the behavior of $\frac{\Gamma(x+\alpha)}{\Gamma(x)} - x^\alpha$ is trivial anyway.
Stirling's formula for the gamma function tells us that
$$ \Gamma(x) = \sqrt{\frac{2\pi}{x}} \left(\frac{x}{e}\right)^x \left[1 + \frac{1}{12x} + O\left(\frac{1}{x^2}\right)\right] \tag{1} $$
as $x \to +\infty$. If $x \to +\infty$ then $x+\alpha \to +\infty$, so we also have the formula
$$ \Gamma(x+\alpha) = \sqrt{\frac{2\pi}{x+\alpha}} \left(\frac{x+\alpha}{e}\right)^{x+\alpha} \left[1 + \frac{1}{12(x+\alpha)} + O\left(\frac{1}{(x+\alpha)^2}\right)\right], \tag{2} $$
valid as $x \to +\infty$. One can check that
$$ 1 + \frac{1}{12(x+\alpha)} + O\left(\frac{1}{(x+\alpha)^2}\right) = 1 + \frac{1}{12x} + O\left(\frac{1}{x^2}\right) $$
as $x \to +\infty$. This, together with a few algebraic manipulations of $(2)$, yields
$$ \Gamma(x+\alpha) = x^\alpha \left(1+\frac{\alpha}{x}\right)^{\alpha-1/2} \frac{\left(1+\frac{\alpha}{x}\right)^x}{e^\alpha} \sqrt{\frac{2\pi}{x}} \left(\frac{x}{e}\right)^x \left[1 + \frac{1}{12x} + O\left(\frac{1}{x^2}\right)\right] \tag{3} $$
as $x \to +\infty$. By dividing $(3)$ by $(1)$ we obtain
$$ \begin{align} \frac{\Gamma(x+\alpha)}{\Gamma(x)} &= x^\alpha \left(1+\frac{\alpha}{x}\right)^{\alpha-1/2} \frac{\left(1+\frac{\alpha}{x}\right)^x}{e^\alpha} \frac{1 + \frac{1}{12x} + O\left(\frac{1}{x^2}\right)}{1 + \frac{1}{12x} + O\left(\frac{1}{x^2}\right)} \\ &= x^\alpha \left(1+\frac{\alpha}{x}\right)^{\alpha-1/2} \frac{\left(1+\frac{\alpha}{x}\right)^x}{e^\alpha} \left[1 + O\left(\frac{1}{x^2}\right)\right] \tag{4} \end{align} $$
as $x \to +\infty$.
By the binomial theorem we have
$$ \left(1+\frac{\alpha}{x}\right)^{\alpha-1/2} = 1 + \frac{(\alpha-1/2)\alpha}{x} + O\left(\frac{1}{x^2}\right) \tag{5} $$
as $x \to +\infty$.
To approximate the factor involving the exponential function we proceed like
$$ \begin{align} \left(1+\frac{\alpha}{x}\right)^x &= \exp\left\{x \log\left(1+\frac{\alpha}{x}\right)\right\} \\ &= \exp\left\{x \left[\frac{\alpha}{x} - \frac{\alpha^2}{2x^2} + O\left(\frac{1}{x^3}\right)\right]\right\} \\ &= \exp\left\{\alpha - \frac{\alpha^2}{2x} + O\left(\frac{1}{x^2}\right)\right\} \\ &= e^\alpha \exp\left\{- \frac{\alpha^2}{2x} + O\left(\frac{1}{x^2}\right)\right\} \\ &= e^\alpha \left[1 - \frac{\alpha^2}{2x} + O\left(\frac{1}{x^2}\right)\right], \tag{6} \end{align} $$
where the steps are valid as $x \to +\infty$.
Plugging $(5)$ and $(6)$ into $(4)$ yields
$$ \begin{align} \frac{\Gamma(x+\alpha)}{\Gamma(x)} &= x^\alpha \left[1 + \frac{(\alpha-1/2)\alpha}{x} + O\left(\frac{1}{x^2}\right)\right] \left[1 - \frac{\alpha^2}{2x} + O\left(\frac{1}{x^2}\right)\right] \left[1 + O\left(\frac{1}{x^2}\right)\right] \\ &= x^\alpha \left[1 + \frac{\alpha^2-\alpha}{2x} + O\left(\frac{1}{x^2}\right)\right] \\ &= x^\alpha + \frac{\alpha^2-\alpha}{2} x^{\alpha-1} + O(x^{\alpha-2}) \end{align} $$
as $x \to +\infty$. Thus
$$ \frac{\Gamma(x+\alpha)}{\Gamma(x)} - x^\alpha \sim \frac{\alpha^2-\alpha}{2} x^{\alpha-1} $$
as $x \to +\infty$, and the right-hand side tends to zero if and only if $\alpha - 1 < 0$.
  • You are right, indeed. I worked with $\frac{(x+a)!}{x!}$ ! I delete my answer. Fixing it, I get the same result as your. Thanks & cheers :) – – Claude Leibovici Jul 05 '14 at 04:04
  • I wish everyone would just agree to define $\Gamma(n) = n!$. It would be much less confusing that way. Perhaps this is a more worthwhile "debate" than pi vs. tau? – Antonio Vargas Jul 05 '14 at 04:11
