I've just started reading through Calculus Made Easy by Silvanus Thompson and am trying to solidify the concept of differentials in my mind before progressing too far through the text.
In Chapter 1 Thompson describes a differential $dx$ as "a little bit of $x$" or "an element of $x$" and then proceeds to describe $\int dx$ as "the sum of all the little bits of $x$." I'm okay upto this point.
In Chapter 2 he begins discussing the various degrees of "smallness" and this is where I begin to lose track. At times his explanation seems to make sense, and then again it does not.
Thompson starts his discussion of degrees of smallness with an appeal to time.
Obviously 1 minute is a very small quantity of time compared with a whole week. Indeed, our forefathers considered it small as compared with an hour, and called it "one minute," meaning a minute fraction - namely one sixtieth - of an hour. When they came to require still smaller subdivisions of time, they divided each minute into 60 still smaller parts, which, in Queen Elizabeth's days, they called "second minutes" (i.e. small quantities of the second order of minuteness).
Now, at this time it seems as though Thompson is making the point that $(dx)^2$ may be considered to be "a little bit of $dx$" or "a little bit of a little bit of $x$," which seems intuitive, but perhaps not consistent with the language.
However, a little later he describes $(dx)^2$ as "a little bit of a little bit of $x^2$. And in doing so, he backs up his statement with a figure of a square with sides of length $x + dx$ and notes that any one of the corners of the square represents the magnitude $(dx)^2$. While not necessarily appealing to my intuition, this description does seem to be more in line with his description of $dx$.
a little bit $\cdot$ $x$ $\cdot$ a little bit $\cdot$ $x$ $=$ a little bit $\cdot$ a little bit $\cdot$ $x^2$
Yet, I don't see how this second description is making the case for $(dx)^2$ being any less significant than $dx$. From the diagram, it actually seems more significant than $dx$, being $dx$ times greater than $dx$.
So I'm wondering, is there a difference between $d^2x$ and $(dx)^2$? Should I read $d^2x$ as "a little bit of a little bit of $x$" and $(dx)^2$ as "a little bit of a little bit of $x^2$?" Am I missing the point entirely? Have I gone completely mad?
In hopes of further clarifying the question, I'm including a little more of what Thompson said:
If $dx$ be a small bit of $x$, and relatively small of itself, it does not follow that such quantities as $x \cdot dx$, or $x^2 \cdot dx$, or $a^x \cdot dx$ are negligible. But $dx \cdot dx$ would be negligible, being a small quantity of the second order.
Furthermore, he states:
[I]n all cases we are justified in neglecting the small quantities of the second - or third (or higher) - orders, if only we take the small quantity of the first order small enough in itself.
