26
I'm learning basic category theory and teaching myself about adjoints. The definition I have is that an adjunction between $F: \mathcal{C} \to \mathcal{D}$ and $G: \mathcal{D} \to \mathcal{C}$ is a bijection, for each pair of an object $A \in Ob(\mathcal{C})$, $B \in Ob(\mathcal{D})$, between morphisms $FA \to B$ in $\mathcal{D}$ and morphisms $A \to GB$ in $\mathcal{C}$, natural in $A$ and $B$: then we say 'G is right-adjoint to F' or 'F is left-adjoint to G'.
My problem is I don't fully understand why a functor would only be right-adjoint or left adjoint: obviously they are not the same thing otherwise you wouldn't give them separate names. If you do have the above setup, then could you not also take your bijection 'in the other direction' between morphisms $GA \to B$ in $\mathcal{C}$ and morphisms $A \to FB$ in $\mathcal{D}$ for $A \in Ob(\mathcal{D})$, $B \in Ob(\mathcal{C})$? Or does the problem lie in the fact that the image of objects $F$ and of $G$ will not necessarily be all of $Ob(\mathcal{C})$ or $Ob(\mathcal{D})$, so we might not be bijecting the same objects/morphisms between them?
Almost certainly this left/right adjoint switching doesn't work but I don't understand why very clearly, hopefully someone here much more experienced can explain things in more simple terms as I'm finding that practically speaking this definition of 'adjunction' isn't very easy for me to work with formally given my inexperience. Sorry if this is too simple a question for Math.Stackexchange! Thanks - Jon
(In addition, if you happen to have a more intuitive understanding of an adjoint than 'one half of a pair of functors between 2 categories for which there is a bijection of the morphisms $FA \to B$ and $A \to GB$ for each pair of objects A, B in their respective categories' then please I would be very grateful to hear how you think of adjoints in practice too! It seems like the notion is a little similar to inverses, but not quite an inverse obviously.)
Arnaud D.
  • 20,884
Jon
  • 263
  • Maybe the answer to this question http://math.stackexchange.com/questions/20364/adjoint-functors-as-conceptual-inverses could add some help. – Agustí Roig Nov 22 '11 at 16:27
    You might also find useful to view the "catsters" videos on youtube.com They have several videos covering adjunctions and many others on selected topics in category theory – magma Nov 23 '11 at 01:40
You ask:
If you do have [a bijection between morphisms FA → B and morphisms A → GB], then could you not also take your bijection 'in the other direction' between morphisms GA → B in C and morphisms A → FB in D [...]?
This argument doesn’t quite work, since taking the bijection in the other direction, it will go between morphisms A → GB and morphisms FA → B. The functor G still only appears on the codomains of morphisms.
To give a concrete example where no such bijection exists: let (F, U) be the “free group”/“underlying set” functors between Set and Gp.
Now, F is left adjoint to U. But they can’t be adjoint the other way round! If they were, that would give a bijection between $\mathbf{Sets}(U1,\phi)$ and $\mathbf{Gp}(1,F\phi)$ (where $1$ denotes the trivial group, and $\phi$ the empty set). But $\mathbf{Sets}(U1,\phi)$ is empty, while $\mathbf{Gp}(1,F\phi)$ has one element, since $F\phi \cong 1$.
An intuition for adjoints? There’s no easy, one-size-fits-all answer; but a good place to start is with these sorts of free/forgetful examples. Typically one can thing of a left adjoint as adding stuff, as freely as possible — perhaps new elements, perhaps some structure, perhaps imposing some equations if necessary. On the other hand, a right adjoint typically forgets things — forgets structure, sometimes perhaps throws away elements too...
The point you mention that they're a generalisation of inverses is also a good one. The Stanford Encyclopedia of Philosophy calls them “conceptual inverses”, which depending on how you feel about philosophy may be very helpful or not at all.
But really the best way to get intuition for adjoints comes from looking at as many examples as possible; not necessarily all in a hurry, but every now and then, for a while. They’re one of those concepts that doesn't usually come quickly (it didn't for me, nor for anyone I've seen learning category theory), but which — if you give it time to percolate, and occasional exercises — will sooner or later “click” and suddenly seem so natural you can't imagine not understanding it.
Incidentally, a similar question was also asked some time ago at mathoverflow. I very much like the current second answer, giving a rather different example of adjoints: viewing the posets Z and R as categories in the usual way (i.e. there's a unique map xy whenever xy), the “ceiling” function RZ is left adjoint to the inclusion ZR, while dually the “floor” function is right adjoint to the inclusion. This suggests the slogan: left adjoints round up (again, adding just as much as is needed to get an integer); right adjoints round down (forgetting the non-integer part).
    Perfect, that's just what I was looking for - the example obviously shows why I was mistaken, thank you! And the intuitive notions are very helpful too, I'll try to track down some good examples to play around with online until I get my head around things. – Jon Nov 22 '11 at 19:57
14
If you're saying that a bijection between sets of morphisms
$$ \mathcal{D} (FA, B) = \mathcal{C}(A, GB) $$
implies necessarily a bijection
$$ \mathcal{D} (B, FA) = \mathcal{C}(GB, A) $$
for every pair of functors $F$ and $G$, then you should prove it. Shouldn't you? -"Why not?" is not a proof.
Anyway, I'll try to show you "why not".
Because there are examples of particular functors $F$ and $G$ where you have the first bijection without having the second one.
Take for instance the first example of adjoint functors in Mac Lane's book:
$$ V: \mathbf{Set} \leftrightarrows \mathbf{Vct_k} : U \ . $$
Here
  • $\mathbf{Set}$ is the category of sets.
  • $\mathbf{Vct_k}$ is the category of $\mathbf{k}$-vector spaces, $\mathbf{k}$ a field.
  • $U$ is the forgetful functor which sends every vector space $W$ to its underlying set of vectors $U(W)$.
  • $V$ is the functor which sends every set $X$ to the vector space $V(X)$ with basis $X$.
This pair of functors are adjoint: $U$ right, $V$ left. You have an easy pair of bijections, inverse one to each other:
$$ \varphi : \mathbf{Vct_k}(V(X), W) \rightleftarrows \mathbf{Set}(X, U(W)): \psi $$
defined as follows:
  • For each function $g: X \longrightarrow U(W)$, $\psi (g) : V(X) \longrightarrow W$ is the unique linear map which extends the function $g$.
  • For each linear map $f: V(X) \longrightarrow W$, $\varphi (f) : X \longrightarrow U(W)$ is the restriction $f_{\mid X}$ of $f$ to the set $X$.
You can check that both compositions $\varphi \circ \psi$ and $\psi \circ \varphi$ are identities.
Now, if your guess was right, you should be able to produce another pair of bijections
$$ \varphi' : \mathbf{Vct_k}(W, V(X)) \rightleftarrows \mathbf{Set}(U(W), X): \psi' $$
Can you?
EDIT. Maybe I should have warned you NOT to try it. Here is a little example that shows that this is impossible (and hence $U$ is a right adjoint to $V$ and $V$ a left adjoint to $U$, but NOT the other way around).
Take $\mathbf{k} = \mathbb{R}$, the real numbers, $W = \mathbb{R}$ and $X = \left\{ *\right\}$ a set with a single element. Then,
  • $V(*) = \mathbb{R}$.
  • $\mathbf{Vct}_{\mathbb{R}} (W, V(X)) = \mathbf{Vct}_{\mathbb{R}}(\mathbb{R}, \mathbb{R}) = \mathbb{R}$.
  • $\mathbf{Set}(U(W), X) = \mathbf{Set}(\mathbb{R}, *) = \left\{ *\right\}$.
So, there is no possible bijection the other way around. Hence, $U$ cannot be left adjoint to $V$ and $V$ cannot be right adjoint to $U$.
Agustí Roig
  • 17,959
    For the OP, it's worth saying that a lot of adjoint pairs have the left adjoint being some "free" structure added on top of some data (like V(X), or the free group functor), and with the right adjoint being a forgetful functor, or even some sort of projection functor that looks at some small piece of data. – Thomas Belulovich Nov 22 '11 at 04:13
  • That's very helpful - thankyou, I think I was lacking in examples to try out more than anything else, I'm working out of a friend's lecture notes. I'm nowhere near a decent library unfortunately but next time I'll spend a little more time googling around to try and find something pertinent. – Jon Nov 22 '11 at 19:55
Left adjoints preserve colimits; right adjoints preserve limits. To ask that a functor preserves both limits and colimits is a fairly strong condition; in the context of abelian categories this is even stronger than being exact, which means preserving just finite limits and colimits.
And examples of nonexact left adjoints between abelian categories abound: take $M$ a non-flat $R$-module, and consider tensoring $- \otimes_R M$ by $M$, which is left adjoint to $\operatorname{Hom}_{R}(M,-)$, but not right adjoint.
