Can you tell me if I got the following homework right? Nitpicking is welcome.
a) Recall that $$ c_0 (\mathbb{N}) = \{ f: \mathbb{N} \rightarrow \mathbb{C} \mid \lim_{n \rightarrow \infty } f(n) = 0\} \subset l^\infty ( \mathbb{N}) $$ is a Banach space with respect to the supremum norm $\| . \|_\infty $. Show that $(c_0(\mathbb{N}))^\ast \cong l^1(\mathbb{N})$ where the dual pairing is given by $$ \langle f, g \rangle = \sum_{n = 0}^\infty f(n) g(n)$$ for $f \in c_0(\mathbb{N})$ and $g \in l^1(\mathbb{N})$.
b) Show that $(l^1(\mathbb{N}))^\ast \cong l^\infty(\mathbb{N})$
c) Compute the dual of $c(\mathbb{N}) = \{ f: \mathbb{N} \rightarrow \mathbb{C} | \lim_{n \rightarrow \infty} f(n) $ exists $\}$
d) Show that $l^1$ is not reflexive by showing that a Banach limit does not come from a pairing as above with an element of $l^1$
My answers:
a) We want to show that $\varphi : l^1(\mathbb{N}) \rightarrow (c_0 (\mathbb{N}))^\ast$ defined by $g \mapsto \langle ., g\rangle$ is an isomorphism. First, I think, we need to verify that it maps into $(c_0 (\mathbb{N}))^\ast$. So let $f \in c_0(\mathbb{N})$. Then $$ | \langle f,g \rangle | = \Big | \sum_{n=0}^\infty f(n) g(n) \Big | \leq \sum_{n=0}^\infty |f(n)| |g(n)| \leq \| f \|_\infty \sum_{n=0}^\infty | g(n)| < \infty$$
Next we need to verify that it's a vector space homomorphism, that is, it's linear. For this, let $\alpha \in \mathbb{C}, g \in l^1(\mathbb{N})$ and $f_1 , f_2 \in c_0(\mathbb{N})$. Then $$ \langle \alpha (f_1 + f_2), g \rangle = \sum_{n=0}^\infty \alpha (f_1 + f_2)(n) g(n) = \alpha \sum_{n=0}^\infty f_1(n)g(n) + \alpha \sum_{n=0}^\infty f_2(n)g(n) = \alpha \langle f_1 , g \rangle + \alpha \langle f_2 , g \rangle$$
Next we need to show that $\varphi$ is injective. For this let $g \in l^1(\mathbb{N})$ such that $\langle f,g \rangle = 0$ for all $f$ in $c_0(\mathbb{N})$. Then in particular, $\langle f_N,g \rangle = 0$ for $$ f_N (n) := \begin{cases} 1 & n = N \\ 0 & otherwise \end{cases}$$ So $g(n) = 0$ for all $n$ and so $\ker \varphi = \{ 0 \}$.
The last thing to verify is that $\varphi$ is surjective. Consider any $\lambda \in c_0(\mathbb{N})^\ast$. For the next step $\mathbb{N}$ should be locally compact and Hausdorff. This would be the case if $\mathbb{N}$ had the discrete topology but the topology is not specified in the homework so I'm not so sure about the following:
By Riesz-Markov there exists a unique regular countably additive complex Borel measure $\mu$ on $\mathbb{N}$ such that $\varphi(f) = \int_X f(x) d \mu$. Set $g(n) := \mu(n)$ then $\varphi(f) = \int_X f(x) d \mu = \sum_{n=0}^\infty f(n) g(n)$. $g(n) \in l^1$ because $\mu$ is regular and therefore has finite measure on each compact set, in particular $\{ n \}$.
b) Here we need to verify that $\varphi^\prime: g \mapsto \langle ., g \rangle$ is an isomorphism where $g \in l^\infty(\mathbb{N})$. By the same arguments as in a) I showed that it maps into $(l^1 (\mathbb{N}))^\ast$, that it's a homomorphism and that it's injective. To verify that it's surjective, consider any $\lambda : l^1(\mathbb{N}) \rightarrow \mathbb{C}$. Then $\lambda$ can be split into positive real functions as follows: $\lambda = \Re (\lambda) + i \Im(\lambda) = \Re (\lambda)^+ - \Re (\lambda)^- + i \Im(\lambda)^+ - i \Im(\lambda)^-$. Then for each part separately, there exists a unique regular measure by the same argument as in a), so $\varphi^\prime$ is surjective.
c) To compute $(c(\mathbb{N}))^\ast$ consider an $s \in c(\mathbb{N})$. Then $\lim_{n \rightarrow \infty} s_n = k$ for some $k \in \mathbb{C}$ and $\lim_{n \rightarrow \infty}(s_n - k) = 0$ so $(s_n - k)$ is an element of $c_0(\mathbb{N})$. Now I'm not sure about my next step. I suspected that if $V, V^\prime$ are isomorphic vector spaces then their duals $V^\ast$ and $(V^\prime)^\ast$ are isomorphic. So I constructed a bijective linear function from $c(\mathbb{N})$ into $c_0(\mathbb{N}) \times \mathbb{C}$ as follows: $s_n \mapsto (s_n - k, k)$ and verified that it's bijective and linear.
d) To show that $l^1$ is not reflexive I used Kakutani's theorem which says that $l^1$ is reflexive if and only if the closed unit ball is weakly compact. To find an open cover of the unit ball that doesn't contain a finite subcover pick $B_1 (f) $, the ball of radius $1$ around $f$ for all $f$ with $\| f \| = 1$. Then any two such $f$ have distance $2$ and therefore no $f$ is in any $B_1 (f^\prime) $ for any $f^\prime$ with $\| f^\prime \| = 1$. There is an infinite number of $f$'s with $\| f \| = 1$ so any finite collection of balls $B_1 (f) $ leave an infinite number of $f$'s uncovered. So $l^1$ is not reflexive.
Thanks for your help!
\mid
instead of|
: compare the previous set with ${x \in X | x \text{ is blah}}$. For the dot as a placeholder it's more standard to use\cdot
instead of a plain period. To insert text into a formula, use the\text{my explanation}
(note that you can adjust spacing by starting/ending it with a blank, so e.g.\text{ my explanation }
. – t.b. Nov 20 '11 at 12:57
