From Multivariate integration of a derivative w.r.t. a single variable, from words_that_end_in_GRY's answer.
From elementary calculus, I always thought $\int^{}$ and $dx$ were just a kind of "command" button to integrate something between the two, rather than a genuine mathematical object.
(I don't mean this is widely accepted definition of the terms, but by "mathematical object" I mean anything that can be subject to mathematical operation. By "command button" I mean symbol for operation of some kind. In "2+2=4" 2 and 4 will be mathematical objects and + and = will be command button.)
That understanding caused no trouble in elementary calculus like
$\int^{} \mathbf f(x) \mathbf {dx}$.
But it starts to confuse me when things like
$g(\mathbf r) = \int^{\mathbf r} \mathbf F(\mathbf r')\cdot \mathbf {dr'}+c$.
comes up. dot product! $dr'$ is being dot producted! Then clearly it sounds like $$dr'$ is some genuine mathematical object.
I remember I felt similar confusion in differential equation course and many others.
In short, what's the true rigorous meaning of dx symbol in general (possibly multivariate) setting?
You want to learn about differential forms. You can start here, but eventually you'll want to read some books.
Ted Shifrin
  • 115,160
