As you observed, we can reduce to the case where $a$ and $b$ are relatively prime.
Given relatively prime positive integers $a$ and $b$, and a positive $c$, we want to find the number of solutions of $ax+by=c$ in positive integers $x$, $y$.
We will give an exact answer, and a much simpler to compute approximate answer which could be off by $1$. The argument that leads to these answers is given below. The answers themselves come after the argument.
There are integers $x_0,y_0$, such that $ax_0+by_0=c$. A solution $(x_0,y_0)$
can be found by using the Extended Euclidean Algorithm to solve the equation $au+bv=1$, and multiplying through by $c$. The details can be found in many places. We will instead concentrate on the consequences. Note that the $x_0$ and $y_0$ found through this process will not be both positive.
Once we have found one solution $(x_0,y_0)$, all integer solutions of the equation $ax+by=c$ have the shape $x=x_0+bt$, $y=y_0-at$, where $t$ ranges over the integers. To produce the positive solutions, we want to find all integers $t$ such that $x>0$ and $y>0$.
So we need $y_0-at >0$, $x_0+bt>0$, or equivalently
$$-\frac{x_0}{b}<t <\frac{y_0}{a}.$$
Exact Answer: The number of positive solutions $(x,y)$ is the number of integers $t$ in the interval $-x_0/b<t <y_0/a$. This is easily determined once we know $x_0$ and $y_0$.
Approximate Answer: The interval $(-x_0/b,y_0/a)$ has width $y_0/a+x_0/b$. which simplifies to $(ax_0+by_0)/ab$, that is, $c/ab$.
If $\dfrac{c}{ab}$ is an integer, then the width of our open interval is an integer, and the number of integers in the interval is $\dfrac{c}{ab}-1$. If $\dfrac{c}{ab}$ is not an integer, then the number of integers in our open interval can be either
$$\left\lfloor \dfrac{c}{ab}\right\rfloor \qquad \text{or}\qquad \left\lfloor \dfrac{c}{ab}\right\rfloor+ 1.$$
For a simple example that shows that $c/ab$ need not quite determine the number of positive solutions, note that $x+15y=23$ has one positive solution, while $3x+5y=23$ has two positive solutions.
If we give the answer $c/ab-1$ if $c/ab$ is an integer, and $\lfloor c/ab\rfloor$ otherwise, we are guaranteed that we are underestimating the true answer by at most $1$.
The advantage is that the approximate answer can be found very cheaply. In our exact answer, we used $x_0$ and $y_0$, so would need to compute these.
