When I feed WolframAlpha an expression like $\sin({\pi\frac{2}{3}})$, it correctly prints that this is equal to $\frac{\sqrt3}{2}$, instead of the decimal expansion $0.866025403\ldots$.
Perhaps it has a lookup table for common fractions of $\pi$. Or is it likely to be more sophisticated? Does it solve the convergence of the series expansion for $\sin(x)$?
    This isn't really a mathematical question, but a question about WA's implementation. Since WA is not open source, we can only guess. I strongly doubt it is using the power series. It is probably just doing the first thing - finding a rational multiple of $\pi$ and doing a lookup. – Thomas Andrews May 16 '14 at 13:01
  • Can you put your comment into an answer with reasons for your claims? –  May 16 '14 at 13:31
    As described in the documentation: "FunctionExpand uses an extension of Gauss's algorithm to expand trigonometric functions with arguments that are rational multiples of $\pi$." – Brendon May 16 '14 at 20:56
It must be that $\sin\left(\dfrac{p}{q}\pi\right)$ is algebraic. To see why check out this question.
I am almost certain that W|A doesn't use power series unless the value is very small simply because it would be too slow to calculate the value of arbitrary trig functions using power series. It is more likely that there is a certain class of rational numbers such as $\frac{1}{3}$ where the forms of $\sin(\frac{\pi}{3})$ and $\cos(\frac{\pi}{3})$ are known and then formulae such as the double angle formula gives results for other rational numbers such as $\sin({\frac{2\pi}{3}})$. The result is then simplified and sent to the user.
This is only a conjecture as I do not have access to any Mathematica source code.
Here is an example. Suppose you know that $$\sin\left(\dfrac{\pi}{2}\right) = 1 \quad\text{and}\quad \cos\left(\dfrac{\pi}{2}\right) = 0.$$
We know that $$\sin^2(\theta) = \dfrac{1-\cos(2\theta)}{2}.$$
It must be that:
$$\sin^2\left(\dfrac{\pi}{4}\right) = \dfrac{1}{2} \quad\text{and}\quad \cos^2\left(\dfrac{\pi}{4}\right) = 1-\dfrac{1}{2} = \dfrac{1}{2}$$
$$\sin\left(\dfrac{\pi}{4}\right) = \dfrac{\sqrt{2}}{2} \quad\text{and}\quad \cos\left(\dfrac{\pi}{4}\right) = \dfrac{\sqrt{2}}{2}.$$
Continuing...
$$\sin\left(\dfrac{\pi}{8}\right) = \dfrac{\sqrt{{2-\sqrt{2}}}}{2} \quad\text{and}\quad \cos\left(\dfrac{\pi}{8}\right) = \dfrac{\sqrt{{2+\sqrt{2}}}}{2}$$
$$\sin\left(\dfrac{\pi}{16}\right) = \dfrac{\sqrt{2-\sqrt{{2+\sqrt{2}}}}}{2} \quad\text{and}\quad \cos\left(\dfrac{\pi}{16}\right) = \dfrac{\sqrt{2+\sqrt{{2+\sqrt{2}}}}}{2} $$
Which agrees with W|A.
Brad
  • 5,156
  • 50
With Mathematica one gets
In[2]:= Sin[2 \[Pi]/3]
Out[2]= Sqrt[3]/2
Wolfram|Alpha possibly just use Mathematica's native capability. About how that's implemented in Mathematica, if you really need to know it, ask it on mathematica.stackexchange.com. My guess is that it uses look-up table for efficiency.
qazwsx
  • 562
Perhaps it has a lookup table for common fractions of π. Or is it likely to be more sophisticated?
All trigonometric functions of rational multiples of $\pi$ are algebraic numbers. This follows from the formula(s) attributed to Leonhard Euler and Abraham de Moivre. Is this what you had in mind?
Lucian
  • 48,334
  • 83
  • 154
