I've recently begun self studying general relativity, using mostly the material found in Robert Wald's "General Relativity", and almost right out of the gate one encounters the notion of a tensor. In Wald's book a $(k,l)$-tensor is simply defined as a multilinear map
$$T : \underset{k-times}{\underbrace{V^*\times \cdots \times V^*}} \times \underset{l-times}{\underbrace{V\times \cdots \times V}} \rightarrow \mathbb{R}$$
where $V$ is a vector space over the reals and $V^*$ is it's corresponding dual space.
My problem with tensors is not so much what they are but rather it stems from a more intuitive standpoint, namely, why use tensors in the first place? Although I suppose it's likely that if I had a better understanding of what they are I would see why they are useful.
Just to provide some context, my first brush with tensors was during an analysis course on manifolds and the discussion of general tensors of the above form ultimately lead to dealing specifically with differential forms, since then this is the only other time i've encountered them. In any case, both in that class and my recent investigation into GR it seems to be that tensors are the natural tool for analyzing manifolds from a differential viewpoint, and my question is: why is that?
To me they seem to be exactly what they are defined to be; multilinear maps, and I just don't see why they are the weapon of choice, per se, for dealing with these sort of ''small (differential-type) changes''.
If you have encountered anything that would aid in building intuition as to why tensors are useful in this context, I would love to hear/read it and it would be greatly appreciated.
  • This looks like it could be useful. I'll give it a read. Thanks @GiuseppeNegro – Andrew Ross May 06 '14 at 22:00
  • Be careful that many people are in the habit of using "tensor" to mean "tensor field" (which I think is terrible: you wouldn't call vector fields vectors). In differential geometry what matters are tensor fields. – Qiaochu Yuan May 07 '14 at 01:12
  • @QiaochuYuan Actually that is one source of confusion I've found while reading Wald's book. Many times it seems as though the object that one should be considering ought to be a tensor field even though he is calling it a tensor. Although, I will admit that it could just be a gap in my understanding. That said, I don't think that clarifying this confusion would result in my understanding of why tensors and tensor fields are particularly useful in this context, unfortunately. – Andrew Ross May 07 '14 at 02:50
There are several properties of tensor that we see reflected in physical quantities in the real world:
Coordinate system independence: a tensor's components transform to precisely counteract how vector and covector components transform under a change of coordinate system. This suggests the tensor is an object unto itself, not tied to a particular coordinate system, and such a notion jives with what we might expect from the real world: that physical, measurable quantities do not depend on the coordinate system chosen.
Generalization of vectors and matrices: Fully antisymmetric tensors correspond to "blades": planes and volumes and so on that can be added or multiplied by scalars in the same way you would do with vectors, and with similar geometric significance. Blades are a very important kind of tensor, and they are among the easiest tensors to visualize.
For matrices, consider that a general matrix might be seen as a linear map of a vector and a covector that produces a number: if $\omega$ is a covector and $v$ a vector with $M$ a matrix, then $\omega(M(v))$ is that scalar, and we could identify it with a tensor $m$ such that $m(v, \omega)= \omega(M(v))$. General tensors simply can take more possible arguments. They could even be said to take blades as arguments instead of plain vectors (the Riemann tensor field, for instance, can be said to take a 2-blade--an oriented plane--as one argument).
In the context of differential geometry, you will deal with a mix of blades and other more general tensors. For instance, every oriented manifold of dimension $n$ has an $n$-blade that describes its orientation: a curve has a tangent vector, a surface has a tangent plane, and so on. This $n$-blade may vary in "direction" at different points. Knowing how it varies gives great insight into how the manifold is curved with respect to its embedding (if it's embedded).
Certain linear map of blades have proven useful for talking about properties of a manifold. Again, the Riemann tensor field is the gold standard here, and you would be best served by trying to understand why and how this tensor field describes curvature, how the commutator of covariant derivatives tells us that, and so on. Here, I would understate the notion that tensors as a whole are powerful tools--they're not, really--but specific tensors are, and what they have in common is that they give us answers that are ultimately coordinate system independent.
Muphrid
  • 19,902
  • This is really interesting. From what I've read, pretty much every piece of literature that had an introductory segment on tensors and tensor fields made a point of outlining how they transformed, but I never really put together the fact that they, in a sense, 'counteracted' the transformations vectors underwent. Honestly, this was exactly the sort of answer I was looking/hoping for, thanks for such a comprehensive answer @Muphrid! – Andrew Ross May 09 '14 at 04:54
  • Tensors are so useful simply because (in addition to invariance) they are linear; that makes them easy to work with. There may be other objects that describe a situation, but are not linear. Think about Taylor series. – mr_e_man Aug 18 '18 at 00:44
