Show: $\gcd(9k+4,2k+1)=1 ~~ \forall k\in \mathbb Z$
Indirect proof.
If  $1\neq d=\gcd(9k+4,2k+1)~\exists k\in \mathbb Z$,
then $d$ has to be of the form $2m+1$ for an integer $m$.
That somehow throws me back at the beginning.
mle
  • 2,287
355durch113
  • 1,570
6 Answers6
Hint $\ $ If $\,d\,$ is a common factor of both then $\,{\rm mod}\ d\!:\ 2k+1\equiv 0\equiv 9k+4.\,$ Now eliminate $\,k\,$ by cross multiplying, to obtain $\,0 \equiv \color{}9(2k+1)-\color{}2(9k+4)\equiv \color{#0a0}9-\color{#c00}8\equiv 1\,\Rightarrow\,d\mid 1,\,$ so $\,d = 1.$
Remark $\ $ More conceptually, $ $ put the fractions for $\,-k\,$ over the common denominator $\,18$
$$ {\rm mod}\ d\!:\ \frac{1}2\,\equiv\, -k\,\equiv\, \frac{4}9\ \Rightarrow\ \frac{\color{#0a0}9}{18}\equiv \frac{\color{#c00}8}{18}\qquad\qquad$$
The fractions uniquely exist mod $\,d\,$ since $\,d\,$ is coprime to $\,2,3\,$ so $\,2,3\,$ are invertible mod $\,d\,$ (else $\,2\mid d\mid 2k+1\,\Rightarrow\,2\mid 1,\ $ or $\ 3\mid d\mid 9k+4\,\Rightarrow\,3\mid 4,\,$ contradiction).
Bill Dubuque
  • 272,048
There is no contradiction. Unless you believe that you can prove $\gcd(15,21)=1$ as well.
I suggest you rather note $d\mid(9k+4)-2\cdot (4k+1)=k+2$ and then $d\mid (4k+1)-4\cdot(k+2)=-7$. Also note that $k=5$ leads to $\gcd(49,21)=7$, i.e. the problem statement is wrong anyway.
  • Typo has been corrected $(4k+1\to 2k+1)$ so this answer no longer applies. Please delete it so as not to confuse readers. – Bill Dubuque Nov 24 '21 at 19:51
Problem statement is wrong because for $k=7n+5,$ $n\geqslant 0$ we have that $\text{gcd}(9k+4,4k+1)$ can be equal to 7.
RFZ
  • 16,814
Note that if $d\ | 9k + 4$, and $d \ | 2k + 1$ then $d\ | (9k + 4) - 4 \cdot (2k + 1) = k$.
But
$\gcd(k, 2k + 1) = 1 \Rightarrow d = k = 1$
This implies $\gcd(9k + 4, 2k + 1) = 1$
Ps The fact that $\gcd(k, 2k+1) = 1$ is easy to see; any number $p$ that divides $k$, also divides $2k$ but do not divide $2k + 1$
Ant
  • 21,098
If $d$ is a common divisor of $a$ and $b$, then $d$ is a common divisor of any (integral) linear combination of $a$ and $b$. If we want to compute $\gcd(9k+4,2k+1)$, a first step might be to find a simple linear combination of $9k+4$ and $2k+1$. But we can take a linear combination that eliminats $k$ completely, namely
$$9(2k+1)-2(9k+4)=18k+9-18k-8=1.$$
Therefore any common divisor must divide $1$, and hence $\gcd(9k+4,2k+1)=1$
Aaron
  • 24,207
-1
Please excuse me for this messed up question,
but I've come up with an answer as compensation:
Just apply the Euclidean algorithm, and in 3 lines you get 1 as GCD.
355durch113
  • 1,570
