For example. Everyone hates $3$, so let's remove it all-together from $\Bbb{Z}$: Let $\Bbb{Z}' = \Bbb{Z} - 3\Bbb{Z}$. Then is there a way to keep it a ring, i.e. $\Bbb{Z}'$ forms a ring by redefining $+$ somehow? By that I mean not too much as obviously any infinite set can be turned into an additive group. But for instance, something like, if $a, b \in \Bbb{Z}', a + b \in 3\Bbb{Z} \implies a + b := 0$. Something simple like that.
Here is a (rather clunky) way of putting an additive structure on ${\Bbb Z}-3{\Bbb Z}$: $$m\oplus n=\Bigl\lceil\frac{m+n+1}{3}\Bigr\rceil +\Bigl\lceil\frac{2m+2n+2}{3}\Bigr\rceil-1\ .$$ Doesn't make a ring structure with ordinary multiplication though, you need to redefine multiplication too, and I think it will look even worse than addition ;-)
- 82,662
Let $p_i, i=1...n$ be a subset of the set $P$ of all primes such that that the set of the other primes $P'=P-\{p_i, i=1...n\}$ is infinite. Let $\mathbb Z'=\mathbb Z-\cup \mathbb p_iZ$. Then you can turn $\mathbb Z'$ into a ring while retaining $\mathbb Z$'s multiplication structure and redefining $+$ as follows:
Since $P$ and $P'$ have the same cardinality there exists a bijection $f: P \to P'$. Extend $f$ to map $0\to 0$, $1\to 1$, and to all integers by mapping $\Pi_j p_j^{k_j}\to \Pi_j f(p_j)^{k_j}$. This obviously preserves multiplication structure.
Then introduce the addition operation: for $a,b\in \mathbb Z'$ define $a+_{\mathbb Z'}b=f(f^{-1}a+_{\mathbb Z}f^{-1}b)$.
It only remains to check whether $\times_{\mathbb Z'}$ is associative relative to $+_{\mathbb Z'}$:
$(a+_{\mathbb Z'}b)\times_{\mathbb Z'} c=f(f^{-1}a+_{\mathbb Z}f^{-1}b)\times_{\mathbb Z'} f(f^{-1}c)=f((f^{-1}a+_{\mathbb Z}f^{-1}b)\times_{\mathbb Z}f^{-1}c)=f(f^{-1}a\times_{\mathbb Z}f^{-1}c+_{\mathbb Z}f^{-1}b\times_{\mathbb Z}f^{-1}c)=f(f^{-1}(a\times_{\mathbb Z'}c)+_{\mathbb Z}f^{-1}(b\times_{\mathbb Z'}c))=a\times_{\mathbb Z'}c+_{\mathbb Z'}b\times_{\mathbb Z'}c$
- 1,649
- 10
- 16
This answer assumes that you've added ${0}$ back into $\mathbb{Z}'$. – Alastair Litterick Apr 11 '14 at 00:11
@Michael Is this new structure isomorphic to $\Bbb{Z}$? I think it is: $f(a + b) = f(f^{-1}a' + f^{-1}b')$ for some $a', b' \in \Bbb{Z}'$ so $ = a' +_{\Bbb{Z}} b' = f(a) +f(b)$. $f$ is a bijection. – Daniel Donnelly Apr 11 '14 at 00:39
Also works if you remove certain infinite subsets of $P$. The key is that we need infinitely many primes to remain. – Karl Kroningfeld Apr 11 '14 at 01:10
@EnjoysMath The method used above is a special case of the method of transporting structure that I mentioned in a comment to your question. – Bill Dubuque Apr 12 '14 at 19:00
Edit: okay, you definitely want the quotient ring. Do you know how that's defined?
– Ian Coley Apr 10 '14 at 23:10
