Let $S$ be a ring with identity and $f: M_{2}(\mathbb{R})\longrightarrow S$ is a nonzero ring homomorphism,then which cases is true?
  1. $S$ is left Artinian
  2. $S$ is left Noetherian
  3. $S$ is simple ring
  4. $S$ has infinite number nilpotent elements
rschwieb
  • 153,510
Ali Qurbani
  • 491
Take any nonzero ring homomorphism $g:M_2(\Bbb R)\to T$ for some nonzero ring $T$.
Then $S=\prod_{i=1}^\infty T$ obviously isn't Noetherian on either side, and it obviously isn't simple.
Define $f:M_2(\Bbb R)\to S$ by $f(x)=(g(x),g(x),\ldots,g(x),\ldots)$, and you have a counterexample to the first three.
There's hope for the fourth statement, though. As Alex pointed out in the comments, $M_2(\Bbb R)$ is simple, and therefore any nonzero ring homomorphism leaving it is injective. The images of nilpotent elements in $M_2(\Bbb R)$ will therefore be nilpotents in $S$. So, if you can show that $M_2(\Bbb R)$ has infinitely many nilpotents $S$ will also have at least that many. (Try it!)
rschwieb
  • 153,510
