I have encountered this problem and I don't know how to approach it, mainly because we can't use L'Hospital's Rule. The limit is as follows:
$$\lim_{x\to a} {x^x-a^a \over x-a}$$
Thanks for any suggestions.
edit: Solved, thanks for the responses.
Hint 1: $$ \begin{align} \frac{e^{x\log(x)}-e^{a\log(a)}}{x-a} &=e^{a\log(a)}\frac{e^{x\log(x)-a\log(a)}-1}{x-a}\\ &=e^{a\log(a)}\frac{e^{\color{#C00000}{x\log(x)-a\log(a)}}-1}{\color{#C00000}{x\log(x)-a\log(a)}}\frac{x\log(x)-a\log(a)}{x-a} \end{align} $$ Hint 2: $$ \begin{align} \frac{x\log(x)-a\log(a)}{x-a} &=\frac{x(\log(x)-\log(a))}{x-a}+\log(a)\\ &=\frac xa\frac{\color{#C00000}{\log(x)-\log(a)}}{e^{\color{#C00000}{\log(x)-\log(a)}}-1}+\log(a) \end{align} $$ Apply $\lim\limits_{x\to0}\frac{e^x-1}{x}=1$.
Although you commented that you could use $\lim\limits_{x\to0}\frac{e^x-1}{x}=1$, here is a proof of this fact using the inequality $1+x\le e^x$. This inequality is shown using Bernoulli's Inequality in this answer.
For $|x|\lt1$, $1+x\le e^x$ and $1-x\le e^{-x}$. Therefore, $$ 1+x\le e^x\le\frac1{1-x} $$ Subtracting $1$ and dividing by $x$ yields $$ \begin{array}{} 1\le\frac{e^x-1}{x}\le\frac1{1-x}&\text{when }x\gt0\\ 1\ge\frac{e^x-1}{x}\ge\frac1{1-x}&\text{when }x\lt0 \end{array} $$ That is, when $|x|\lt1$, $$ \frac{e^x-1}{x}\text{ is between }1\text{ and }\frac1{1-x} $$ By the Squeeze theorem, $$ \lim_{x\to0}\frac{e^x-1}{x}=1 $$
No we can use Lopital's rule so
If $y=x^x$ and $x\gt0$ then $\ln(y)=\ln(x^x)$ Use properties of logarithmic functions to expand the right side of the above equation as follows. $$ \ln(y)=x\ln(x) $$ We now differentiate both sides with respect to x, using chain rule on the left side and the product rule on the right. $$ y'(1/y)=\ln(x) + x(1/x)=\ln(x) + 1 \text{, where }y'=\mathrm{d}y/\mathrm{d}x $$ Multiply both sides by $y$ $$ y'=(\ln(x) + 1)\,y $$ Substitute $y$ by $x^x$ to obtain $$ y'=(\ln(x) + 1)\,x^x $$ then $$ \lim_{x\to a} {x^x-a^a \over x-a}=\lim_{x\to a} {(\ln(x) + 1)\,x^x \over 1}=(\ln(a) + 1)\,a^a $$
[Solved]
. Besides, someone may come up with a better solution; adding[Solved]
to the title might discourage them. – robjohn Mar 04 '14 at 22:00
