14
I have not been able to solve this problem. Any insights would be appreciated!
Let $x, n > 1$ be integers. Suppose that for each $k > 1$ there exists an integer $a_{k}$ such that $x − a_k^n$ is divisible by $k$. Prove that $x = A^{n}$ for some integer $A$.
Parcly Taxel
  • 103,344
    In fancy language: if $x$ is locally an $n$-th power, then $x$ is globally an $n$-th power. This is a (sucessful) instance of Hasse's local-global principle: http://en.wikipedia.org/wiki/Hasse_principle – lhf Oct 16 '10 at 21:04
    See also http://math.stackexchange.com/questions/6758/showing-x8-equiv-16-pmodp-is-solvable-for-all-primes-p which shows that solvability for all primes is not enough. A complete solution is in "A Conjecture of Chowla" by Ankeny and Rogers: http://www.jstor.org/stable/1969571 – lhf Oct 18 '10 at 01:12
    This is IMO Shortlist 2007, Problem N2. https://www.imo-official.org/problems/IMO2007SL.pdf – Evan Chen Dec 17 '15 at 07:02
  • The correct result is here: https://en.wikipedia.org/wiki/Grunwald%E2%80%93Wang_theorem – Qiaochu Yuan Sep 11 '20 at 09:22
7 Answers7
26
To show that $x$ is a perfect $n$th power, it suffices to show that for all primes $p$, the number of times that $p$ divides into $x$ is a multiple of $n$.
To that end, fix any prime $p$, and let $r_p$ be the largest integer such that $p^{r_p}$ divides $x$. Consider $k=p^{r_p+1}$. Then, since $k$ divides $a_k^n -x$, $p^{r_p}$ divides $a_k^n$.
Moreover, it cannot be that $k = p^{r_p + 1}$ divides $a_k^n$. If it were so, then since $p^{r_p + 1}$ divides $a_k^n - x$, $p^{r_p + 1}$ would divide $x$, which contradicts the maximality of $r_p$.
Therefore, $p^{r_p}$ divides $a_k^n$ but $p^{r_p + 1}$ does not; it follows that $r_p$ is equal to the number of times $p$ divides into $a_k^n$, which must be a multiple of $n$ (consider the prime factorization of $a_k^n$), so we are done.
D.W.
  • 4,540
23
I found this question 6 years later. Worth emphasis: there is a much simpler proof, namely choose $\,k^{\phantom{|^{|^|}}}\!\!\!=x^2\,$ so $\,x^2\mid x-a^n\Rightarrow\, \color{#c00}{x\mid a^n}\,$ so $\,\overbrace{ jx^2\! = x-\color{#c00}{mx}}^{\textstyle x^2\mid\, x-\color{#c00}{a^n}}\,$ for $\,j,m\in\Bbb Z.\,$ Solving for $m\Rightarrow\,$ $\,m = 1-j\:\!x\,$ is $\rm\color{#08d}{coprime}$ to $\,x\,$ hence $\,\color{#c00}{a^n=mx}\Rightarrow \,$ $\color{#c00}{m\ \&\ x}^{\phantom{|^{|^|}}}\!\!\!\!\ $ must be $\,n$'th powers too.
Bill Dubuque
  • 272,048
18
This is an old chestnut: an integer which is an $n$-th power modulo all primes is an $n$-th power.
There is a sledgehammer proof via the Chebotarev density theorem. Suppose for the moment that $n$ is prime. Consider $K=\mathbb{Q}(x^{1/n})$ and its Galois closure $L=\mathbb{Q}(x^{1/n},\exp(2\pi i/n))$. Then each prime $p$ that is unramified in $L$ splits in $K$ into various prime ideals at least one of which has norm $p$. So its Frobenius has a fixed point on the permutation representation on the $n$-th roots of $x$. By Chebotarev, the Galois group $G$ of $L/\mathbb{Q}$ has no element of degree $n$ and so must have a fixed point; that is one of the $n$-th roots of $x$ must lie in $\mathbb{Q}$.
I'm sure something similar works for any positive integer $n$, but it's too late tonight for me to work out the details :-)
Robin Chapman
  • 22,310
15
If I am not mistaken, the question has a more elementary answer than those provided so far. I will use the functions $\operatorname{ord}_p: \mathbb{Q}^{\times} \rightarrow \mathbb{Z}$, defined to be the largest power of $p$ appearing in the numerator minus the largest power of $p$ appearing in the denominator.
Step 1: A positive rational number $x$ is a rational $n$th power iff for all primes $p$, $\operatorname{ord}_p(x)$ is divisible by $n$.
This is an easy consequence of unique factorization in $\mathbb{Z}$.
Step 2: A positive integer $x$ is an integral $n$th power iff for all primes $p$, $\operatorname{ord}_p(x)$ is divisible by $n$.
This follows easily from Step 1 using the fact that since $\mathbb{Z}$ is a UFD, it is integrally closed. (Alternately, apply the rational roots theorem to the polynomial $t^n - x$.)
Step 3: As in lhf's comment above, I claim that the given condition on $x$ implies that $x$ is an nth power in $\mathbb{Q}_p$ for all primes $p$. Indeed, taking $k$ to be a prime power, it implies that for all positive integers $a$, the congruence $t^n -x \equiv 0 \pmod{p^a}$ has a solution, and by a routine application of Hensel's Lemma, this implies that $x$ is an $n$th power in $\mathbb{Q}_p$.
Step 4: Since $x$ is an $n$th power in $\mathbb{Q}_p$, the $p$-adic valuation $v_p(x)$ is divisible by $n$. For a rational number $x$, this means that $\operatorname{ord}_p(x)$ is divisible by $n$. And we are done.
As regards the fancy stuff, perhaps people are thinking of the Grunwald-Wang Theorem.
This says that if $x$ is an element of a global field $K$ which is an $n$th power in all but finitely many completions at finite places $v$. Actually, this is "Grunwald's theorem", i.e., it isn't quite true! Wang showed that there are counterexamples to this statement, even over $\mathbb{Q}$ (if one uses all but finitely many places, rather than all places): see the wikipedia article for an explanation. The easy proof that I give above works in any global field which is the fraction field of a PID $R$, with the conclusion that $x$ comes out to be an $n$th power up to a unit of $R$. (When $R = \mathbb{Z}$, requiring $x$ to be positive fixes the unit ambiguity.)
Pete L. Clark
  • 97,892
12
To be a little more concrete, here's the proof for $n = 2$. We proceed by proving the contrapositive. Suppose $x$ is not a square, so write $x = k^2 p_1 p_2 ... p_n$ where the $p_i$ are distinct primes, one of which may be $-1$. By quadratic reciprocity, together with the CRT, there exists an arithmetic progression such that any prime $q$ in that arithmetic progression has the property that $\left( \frac{p_i}{q} \right) = 1$ for $1 \le i \le n-1$ and $\left( \frac{p_i}{q} \right) = -1$ for $i = n$. A prime $q$ exists in this arithmetic progression by Dirichlet's theorem (a special case of Chebotarev's density theorem!), and $x$ is not a square $\bmod q$.
Similarly for $n = 3$ one can give a proof using cubic reciprocity, and so on. In general it should be possible to give a proof along these lines using Artin reciprocity, but if you're using Artin reciprocity and Dirichlet's theorem you might as well use the full strength of Chebotarev.
Qiaochu Yuan
  • 419,620
    This approach appears in second page of Marshall Hall, "Quadratic residues in factorization", Bull. Amer. Math. Soc. 39 (1933), no. 10, 758–763. doi – lhf Apr 18 '11 at 18:42
Here's an elementary proof, using the Jacobi symbol $(\frac{x}{a})$, of the fact that:
$x\in\mathbb{N}\text{ not a square }\Rightarrow\text{ for infinitely many prime numbers }p\text{, } x\text{ is not a square mod }p$
We may assume $x$ is square-free. Consider the group homomorphism $f:a\pmod {4x}\mapsto (\frac{x}{a})$ from $(\mathbb{Z}/4x)^{*}$, the group of units of $\mathbb{Z}/4x$, to $\{\pm 1\}$, where one takes a positive representative $a$ of the residue class. Using the properties of the Jacobi symbol, it is easy to see that $(\frac{x}{a})$ $=$ $(\frac{x}{a+4x})$ for $a\in\mathbb{N}$ relatively prime to $4x$, so that the definition does not depend on the particular positive representative chosen.
$f$ is not the trivial homomorphism. For if $x$ is odd, say $x=p_{1}\cdots p_{s}$ with the $p_{i}$ different primes and $s\geq1$, let $b$ be a quadratic non-residue mod $p_{1}$. Using the Chinese Remainder Theorem, take an $a\in\mathbb{N}$ such that $a\equiv b\text{ mod }p_{1}$, $a\equiv 1\text{ mod }p_{i}$ for $2\leq i\leq s$, and $a\equiv 1\text{ mod }4$. Then $(\frac{x}{a})=(\frac{a}{x})=-1$. For $x=2$ one has $f(3\text { mod }8)=-1$. And if $x=2y$ with $y=p_{1}\cdots p_{s}$ and the $p_{i}$ different odd primes as before, then one has $(\frac{x}{a})=-1$ for $a$ as above if we let $a\equiv 1\text{ mod }8$ rather than $\text{mod }4$.
The statement now follows by applying the following simple lemma to $H:=\text{ker}(f)$.
Lemma: $n\in\mathbb{N},\,H<(\mathbb{Z}/n)^{*}\text{ a proper subgroup }\Rightarrow\text{ for infinitely many primes }p\text{, } p\text{ mod }n\notin H$
Proof. Suppose $p_{1},\cdots,p_{s}$ are the only primes not dividing $n$ with residue class $\text{mod }n$ not in $H$. In case $s=0$, pick any $m\in\mathbb{N}$ relatively prime to $n$ such that $m\text{ mod }n\notin H$. And if $s\geq1$, then $p_{1}\cdots p_{s}$ and $p_{1}^{2}p_{2}\cdots p_{s}$ cannot both be in $H$ $\text{mod }n$, and we let $m$ be either of them that satisfies $m\text{ mod }n\notin H$. But $m\text{ mod }n=(m+n)\text{ mod }n$, and this is an element of $H$, because we have $q\text{ mod }n\in H$ for every prime factor $q$ of $m+n$ (as such a $q$ cannot be among the $p_{i}$). Contradiction.
I don't remember where I picked up this little gem. Its proof uses little more than the concept of a subgroup! Yet it yields many special cases of Dirichlet's theorem on primes in arithmetic progressions. It shows, for example, that there are infinitely many primes $p\equiv 2\text{ mod }3$.
A more elementary proof for the following:
If $x\in \mathbb{Z}$ is a square-free number not a member of $\{0,1\}$, then there exists infinitely many prime numbers such as $p$ where $(\frac{a}{p})=-1$.
Suppose the contrary. Let $p_1,\dots,p_k$ be all the odd primes where $(\frac{a}{p}) = -1$. Consider two cases:
  • $a<0$ : Let $N$ be $4p_1^2p_2^2\dots p_k^2(-a)-1$. There exists a prime number $q$ such that $q|N, q\overset{4}\equiv 3$. From the definition of $N$ we have $q\neq p_i, (q,a)=1$. However, $4p_1^2p_2^2\dots p_k^2(-a) \overset{q}\equiv 1 \Rightarrow (\frac{4p_1^2p_2^2\dots p_k^2 (-a)}{q})=(\frac{-a}{q})=-(\frac{a}{q})=1$ which disproves our initial assumption, proving our case.
  • $a>0$: Let $a=2^\alpha m$ where $\alpha \in{0,1}$ and $m$ is an odd integer. For $m=1$ we have $a=2$, for which we have infinitely many prime numbers $p$ satisfying $p\overset{8}\equiv \pm 3$. For $m>1$, $m$ have at least one odd prime factor such as $q$. Let $\beta$ be a quadratic non-residue modulo $q$. Due to chinese remainder theorem, there exists an integer $s$ satisfying the following: $$s\overset{8p_1p_2\dots p_k\frac{m}{q}} \equiv 1$$ $$s\overset{q} \equiv \beta$$ Then we have $(s,2ap_1\dots p_k)=1$, and using the Jacobi symbol, $$(\frac{s}{\frac{m}{q}})=1, (\frac{s}{q})=-1\Rightarrow (\frac{s}{m})=-1\Rightarrow (\frac{m}{s})*(-1)^\frac{(s-1)(m-1)}{2}=(\frac{m}{s})=-1$$
Let $s={q_1}^{\alpha_1}{q_2}^{\alpha_2}\dots{q_t}^{\alpha_t}$. Due to the initial assumption, $(\frac{a}{q_1})=(\frac{a}{q_2})=\dots=(\frac{a}{q_t})=1$. Therefore, $$(\frac{m}{s})=(\frac{2^\alpha}{s})(\frac{m}{s})=(\frac{a}{s})=(\frac{a}{q_1})^{\alpha_1}(\frac{a}{q_2})^{\alpha_2}\dots(\frac{a}{q_t})^{\alpha_t}=1\Rightarrow (\frac{m}{s})=1$$ Which is the contradiction that finalizes our proof.
