I have been reading the post:
Simple Complex Number Problem: $1 = -1$
and other similar posts based on the manipulation of complex numbers.
If I want to simplify $\sqrt{(-1) \times (-1)}$, I would, using phasor algebra, do
$$\sqrt{(-1) \times (-1)} = \sqrt{-1} \times \sqrt{-1} = 1 \angle 90 \times 1 \angle 90 = 1 \angle 180 = -1$$
I believe the above way is neater and that I have the right answer.
Please do let me know what you think.
PS: What I'm doing is to avoid simplifying when under the square-root sign.
Thanks a lot...
$\LaTeX$
gives $\LaTeX$. You should be able to edit the original question and see how I've revised the original markup. And no, you can't do that decomposition as it's only valid for nonnegative numbers. ($-1$ is obviously negative.) – anon Oct 03 '11 at 08:08
