$\alpha_n \in \mathbb{R}$ is a fixed sequence of real numbers, for which the following holds:
$$ \forall t \in \mathbb{R}, \lim_{n \rightarrow \infty}e^{i\alpha_nt} = 1 $$
Is it necessarily the case that $\lim_{n \rightarrow \infty} \alpha_n = 0$?
Evan Aad
  • 11,422
Assume (as we may) that $\alpha_n\neq 0$ for all $n$. By the dominated convergence theorem and the assumption on $\alpha_n$, we have $$\lim_{n\to\infty} \int_0^1 e^{i\alpha_n t}dt=1\, .$$ On the other hand, $$\int_0^1e^{i\alpha_n t}dt=\frac{1}{i\alpha_n} (e^{i\alpha_n}-1)\, .$$ Since $e^{i\alpha_n}-1\to 0$, it follows that $\alpha_n\to 0$.
Etienne
  • 13,636
The convergence of $e^{i\alpha_n t}$ to $1$ implies the convergence of each component (real and imaginary part): $$\lim_{n \rightarrow \infty}sin(\alpha_nt)=0$$ $$\lim_{n \rightarrow \infty}cos(\alpha_nt)=1$$ If we take $\alpha$ as the limit of $\alpha_n$ distinct of $0$ and take $t=\frac{1}{\alpha}$ by continuity of the functions cos and sin the limit have to be $cos(1)$ and $sin(1)$ then we have a contradiction with the original statement. And then we have two options: or $\alpha_n$ converges to $0$ or not converges.
If $\alpha_n$ have a convergent subsequence for each one of they we could apply the same argument an we have that limit points are $0$ then the problem is reducted to demostrate a contradiction in having a not convergent subsequence.
If the subsequence $\alpha_{n_k} \rightarrow \infty$ like @GEdgar said is a contradiction with the convergence of sin or cos (because the limit at infinity of both functions is not defined at infinity). Finally by this question the subsequence not having cluster points and being bounded converges to infinity, again a contradiction.
rlartiga
  • 4,205
  • 24
Let $\alpha_n$ be a sequence such that $$ \lim_{n \to \infty}e^{i \alpha_n t} = 1\qquad\text{for all } t \in \mathbb R . \tag{1} $$ Suppose $\alpha_n$ does not converge to zero. Replacing some $\alpha_n$ by $-\alpha_n$ if necessary, and taking a subsequence if necessary: we may assume there is $K>0$ so that $\alpha_n \ge K$ for all $n$. Next, we may assume $\alpha \to \infty$: if not, there is a bounded subsequence, say $\alpha_n \le L$, and then $t = \pi/L$ contradicts the convergence (1) along that subsequence.
Now, for each $N \in \mathbb N$, define $$ E_N = \bigcap_{n=N}^\infty \left\{t \in \mathbb R \colon \left| e^{i\alpha_n t}-1\right| \le \frac{1}{10}\right\} . $$ The sets $E_N$ are closed, but by (1) we have $$ \bigcup_{N \in \mathbb N} E_N = \mathbb R . $$ By the Baire Category Theorem, some set $E_N$ is somewhere dense: there is an interval $(a,b) \subseteq E_N$, say. But since $\alpha_n \nearrow \infty$, there is $n \ge N$ so that $\alpha_n(b-a) > 2\pi$. This means $$ \{e^{i \alpha_n t}\colon t \in (a,b)\} $$ covers the entire circle, so $$ \left|e^{i\alpha_n t}-1\right| < \frac{1}{10} $$ fails for some $t \in E_N$. Contradiction.
GEdgar
  • 111,679
$\exp$ is $2\pi i$ periodically, so the answer is No. (if you mean $t\rightarrow\infty$)
edit: see comments
Max
  • 1,307
    I was interpreting the question to mean $t\in \mathbb{R}$ is fixed, and $n\to \infty$. There is actually some work to do here, I think.... – froggie Feb 27 '14 at 19:31
  • ah okay... then still $t\alpha_{n}$ can have multiple cluster points around multiples of $2\pi$ – Max Feb 27 '14 at 19:32
  • yes, but then if you choose $t = 1/2$, then you wouldn't get the convergence to $1$ (unless I misunderstand something) – froggie Feb 27 '14 at 19:33
  • But what about convergence of $e^{i \alpha_n t}$ for all $t$? – GEdgar Feb 27 '14 at 19:33
  • if that convergence holds for all $t$ with the same series $\alpha_{n}$ then it should be possible to show that $\alpha_{n}\rightarrow 0$ – Max Feb 27 '14 at 19:35
  • the question has been edited – Max Feb 27 '14 at 19:39
  • maybe you could use continuity of $p\mapsto p^{\frac{1}{t}}$ for $t>0$ (this is just a guess) – Max Feb 27 '14 at 19:42
  • "should be" ... but "needs proof". – GEdgar Feb 27 '14 at 19:45
  • yes but that would be work... you might want to consider several cases: convergent subsequence and sequence has no clusterpoints, i think i would start from there. – Max Feb 27 '14 at 19:48
