17
Letting
$$\begin{align*}x&=f(t)\\y&=g(t)\end{align*}$$
the following expressions are well known:
$$\begin{align*}\frac{\mathrm dy}{\mathrm dx}&=\frac{g^\prime (t)}{f^\prime (t)}\\\frac{\mathrm d^2 y}{\mathrm dx^2}&=\frac{f^\prime (t)g^{\prime\prime} (t)-g^\prime (t)f^{\prime\prime} (t)}{f^\prime (t)^3}\end{align*}$$
With some effort, we can derive the expression for the third derivative:
$$\frac{\mathrm d^3 y}{\mathrm dx^3}=\frac{f'(t) \left(g^{(3)}(t) f'(t)-3 f''(t) g''(t)\right)+g'(t) \left(3 f''(t)^2-f^{(3)}(t)f'(t)\right)}{f'(t)^5}$$
After deriving expressions for the next higher derivatives, I am unable to detect any particular pattern in the expressions, save for the denominator $f'(t)^{2n-1}$ of the $n$-th derivative. I've also tried to search around for information on the derivatives of parametrically-defined functions, but no dice.
Here then is my question: is there a general formula for $\dfrac{\mathrm d^n y}{\mathrm dx^n}$ in terms of $f(t),g(t)$ and their derivatives?
    If $;\mathrm{d}^ny/\mathrm{d}x^n=h_n(t)f,'(t)^{1-2n}$ then $h_1=g'$ and $h_{n+1}=h'_nf,'-(2n-1)h_nf;''$. I got that much. – anon Oct 01 '11 at 11:47
    My instinct says that an elementary formula is unlikely since the $n$-th derivative will be a linear combination of a product of $(n-1)$ derivatives of $f$ (of various degrees) and a derivative of $g$ (of some degree). This means we have a $n$-dimensional array of coefficients for $\dfrac{\mathrm{d}^n y}{\mathrm{d} x^n}$... – Zhen Lin Oct 01 '11 at 11:54
    I guess you could 'factorize' it as $$\frac{d^ny}{dx^n}=\frac{1}{(f')^{2n+1}}\left[\prod_{k=1}^n\left(f'\frac{d}{dt}-(2k-1)f''\right)\right]g'.$$ Edit: It seems I can't make the $d$'s above into \mathrm style in comments, but I can in the answer preview. – anon Oct 01 '11 at 11:57
    @Zhen: I know (and I did have the foresight not to say the word "elementary" in the question body); I'm down with an expression involving Bell polynomials or somesuch. ;) – J. M. ain't a mathematician Oct 01 '11 at 11:58
    Well, actually, perhaps something might be possible if we use the Faà di Bruno formula. After all, in order to divide by $f'(t)$, $f'(t) \ne 0$, and so $f$ is locally invertible by the inverse function theorem. Then we can express $y$ as a function of $x$ (locally) by a composite of $g$ and $f^{-1}$... – Zhen Lin Oct 01 '11 at 12:01
  • @anon: your recurrence and "operator product" formulae look good; I wonder if there's a more explicit version of those. The reason why I'm trying to look for an explicit expression is that I have values of $f^{(n)}(t)$ and $g^{(n)}(t)$ for a given value of $t$ available, so I'm hoping for a formula I can plug these values into... – J. M. ain't a mathematician Oct 01 '11 at 12:06
  • @anon it seems to me that you meant $\frac{d^{n+1}y}{dx^{n+1}}=\frac{1}{(f')^{2n+1}}\left[\prod_{k=1}^n\left(f' \frac{d}{dt}-(2k-1)f''\right)\right]g'.$ – Immanuel Weihnachten Oct 01 '11 at 12:29
    @Emanuele: Yes, that's correct. Now if we take the concept Zhen mentioned and split $$h_n=\sum_{m=1}F_{m,n} g^{(m)},$$ where $F_{0,m}$ and $F_{k,m}$ for $k>m$ are identically $0$, we obtain $$F_{m,n+1}=f'(F_{m-1,n}+F'{m,n})-(2n-1)f''F{m,n}$$ Eck. – anon Oct 01 '11 at 12:39
  • @J.M.: I added some results to my original answer that may interest you. I'm not sure whether you'll be notified when I edit an old answer, so I'm pinging you as well. – Mike Spivey Dec 11 '12 at 05:43
New answer:
Three formulas for the $n$th derivative of a parametrically-defined function appear in Section 3 of Todorov's paper "New Explicit Formulas for the $n$th Derivative of Composite Functions," Pacific Journal of Mathematics 92 (1): 1981, pp. 217-236. Despite the English title, the paper is in German. None of the three formulas look like they would be particularly easy to use, but that's probably to be expected given the discussion in my original answer.
The first formula, apparently due to Pourchet, is $$\frac{d^n y}{dx^n} = \sum_{k=1}^n B_{nk}(t) g^{(k)}(t),$$ where the functional coefficients $B_{nk}$ satisfy the recurrence relation $$B_{n+1,k} = \frac{1}{f'} \left( B'_{nk} + B_{n,k-1} \right),$$ for $1 \leq k \leq n+1$ and $n \geq 1$. The boundary values are $B_{n0} = B_{n,n+1} = 0$, $B_{11} = 1/f'$.
The next two formulas are explicit and are due to Todorov, but they involve determinants. First we have $$\frac{d^n y}{dx^n} = \frac{1}{(f')^{n(n+1)/2}} \begin{vmatrix} \dfrac{d}{dt} \dfrac{f}{1!} & \dfrac{d}{dt} \dfrac{f^2}{2!} & \cdots & \dfrac{d}{dt} \dfrac{f^{n-1}}{(n-1)!} & \dfrac{dg}{dt} \\ \dfrac{d^2}{dt^2} \dfrac{f}{1!} & \dfrac{d^2}{dt^2} \dfrac{f^2}{2!} & \cdots & \dfrac{d^2}{dt^2} \dfrac{f^{n-1}}{(n-1)!} & \dfrac{d^2g}{dt^2} \\ \vdots & \vdots & \ddots & \vdots & \vdots \\ \dfrac{d^n}{dt^n} \dfrac{f}{1!} & \dfrac{d^n}{dt^n} \dfrac{f^2}{2!} & \cdots & \dfrac{d^n}{dt^n} \dfrac{f^{n-1}}{(n-1)!} & \dfrac{d^ng}{dt^n} \end{vmatrix},$$ which at least has nice symmetry.
The second general formula given by Todorov is $$\frac{d^n y}{dx^n} = \frac{1}{(f')^{2n-1}} \begin{vmatrix} a_{11}(n) \dfrac{f'}{1!} & 0 & \cdots & 0 & \dfrac{g'}{0!} \\ a_{21}(n) \dfrac{f''}{2!} & a_{22}(n) \dfrac{f'}{1!} & \cdots & 0 & \dfrac{g''}{1!} \\ \vdots & \vdots & \ddots & \vdots & \vdots \\ a_{n-1,1}(n) \dfrac{f^{(n-1)}}{(n-1)!} & a_{n-1,2}(n) \dfrac{f^{(n-2)}}{(n-2)!} & \cdots & a_{n-1,n-1}(n) \dfrac{f'}{1!} & \dfrac{g^{(n-1)}}{(n-2)!} \\ a_{n1}(n) \dfrac{f^{(n)}}{n!} & a_{n2}(n) \dfrac{f^{(n-1)}}{(n-1)!} & \cdots & a_{n,n-1}(n) \dfrac{f''}{2!} & \dfrac{g^{(n)}}{(n-1)!} \end{vmatrix},$$ where $a_{jk}(n) = (j-k+1)n - j$, for $1 \leq k \leq \min\{j,n-1\}$ and $1 \leq j \leq n$.
Todorov has some other formulas involving special cases of $f$, as well as results on the $n$th derivative of composite functions (as the title of the paper indicates).
In general, the operation on the right-hand side of $$\frac{d^n y}{dx^n} = \left(\frac{1}{f'} \frac{d}{dt}\right)^n g(t)$$ (which I have in my original answer) is called a Lie derivative. That appears to be the magic word here. (My running across this term in another setting is what led me to Todorov's paper.)
There are two special cases of this formula, given in Comtet's Advanced Combinatorics (p. 220), that are particularly interesting. If $f(t) = \log t$, then $1/f'(t) = t$, and $$\frac{d^n y}{dx^n} = \left(t \frac{d}{dt}\right)^n g(t) = \sum_{k=1}^n \left\{ n \atop k \right\} t^k g^{(k)}(t).$$ If $f(t) = \dfrac{e^{-at}}{-a}$, then $1/f'(t) = e^{at}$, and $$\frac{d^n y}{dx^n} = \left(e^{at} \frac{d}{dt}\right)^n g(t) = \sum_{k=1}^n \left[ n \atop k \right] a^{n-k} g^{(k)}(t).$$
**Original answer**:
In general, thanks to the chain rule, we have $$\frac{d^n y}{dx^n} = \left(\frac{1}{f'(t)} \frac{d}{dt}\right)^n g(t).$$ So a large part of the difficulty in finding a nice expression for $\frac{d^n y}{dx^n}$ lies in the form of $f'(t)$. The uglier $f'(t)$ is, the uglier this expression will be.
Looking at a simple case for $f'(t)$ should shed some light on the general case. Letting $f'(t) = 1$ is too simple, but the case $f'(t) = t$ (so, say, $f(t) = t^2/2$) gives some insight. See the end of the post for comments about what this case means for the general case.
If $f'(t) = t$ we have $$\frac{d^n y}{dx^n} = \frac{(-1)^{n-1}\phi_{n-1} (-t D(g'))}{t^{2n-1}} ,$$ where $D$ is the differentation operator (so $D^k(g') = g^{(k+1)}(t)$) and $\phi_n$ is the $n$th reverse Bessel polynomial.
The $n$th reverse Bessel polynomial is defined to be $$\phi_n(t) = \sum_{k=0}^n \frac{(2n-k)! t^k}{(n-k)! k! 2^{n-k}}.$$
For example, for some small values of $n$ we have $$ \begin{align*} \frac{dy}{dx} &= \frac{g'(t)}{t} = \frac{\phi_0 (-t D(g'))}{t}, \\ \frac{d^2y}{dx^2} &= \frac{g''(t)t - g'(t)}{t^3} = -\frac{ \phi_1 (-t D(g'))}{t^3}, \\ \frac{d^3y}{dx^3} &= \frac{g'''(t)t^2 - 3g''(t)t + 3g'(t)}{t^5} = \frac{\phi_2 (-t D(g')}{t^5}, \\ \end{align*}$$ which agrees with what J.M. has above. (Note that $D^0(g') = g'(t).)$ From here we do a proof by induction.
We will need $\frac{d\phi_{n-1} (-t D(g'))}{dt}$, so let's calculate that first. Once we get through the differentiation we'll substitute $z$ for $-t D(g')$, for simplicity's sake. $$\begin{align*} \frac{d\phi_{n-1} (-t D(g'))}{dt} &= -\sum_{k=1}^{n-1} \frac{(2n-2-k)! k (-t)^{k-1} D^k (g')}{(n-1-k)! k! 2^{n-1-k}} + \sum_{k=0}^{n-1} \frac{(2n-2-k)! (-t)^k D^{k+1} (g')}{(n-1-k)! k! 2^{n-1-k}} \\ &= \frac{1}{t} \left(\sum_{k=1}^{n-1} \frac{(2n-2-k)! z^k}{(n-1-k)! (k-1)! 2^{n-1-k}} - \sum_{k=0}^{n-1} \frac{(2n-2-k)! z^{k+1}}{(n-1-k)! k! 2^{n-1-k}}\right) \\ &= \frac{1}{t} \left(\sum_{k=0}^{n-2} \frac{(2n-3-k)! z^{k+1}}{(n-2-k)! k! 2^{n-2-k}} - \sum_{k=0}^{n-1} \frac{(2n-2-k)! z^{k+1}}{(n-1-k)! k! 2^{n-1-k}}\right) \\ &= \frac{1}{t} \left(- z^n + z \sum_{k=0}^{n-2} \frac{(2n-3-k)! z^k}{(n-1-k)! k! 2^{n-1-k}} \left(2(n-1-k) - (2n-2-k)\right) \right) \\ &= -\frac{1}{t} \left( z^n + z \sum_{k=0}^{n-2} \frac{(2n-3-k)! k z^k}{(n-1-k)! k! 2^{n-1-k}} \right) \\ &= -\frac{1}{t} \left( z^n + z^2 \sum_{k=0}^{n-3} \frac{(2n-4-k)! z^k}{(n-2-k)! k! 2^{n-2-k}} \right) \\ &= -\frac{z^2}{t} \phi_{n-2} (z). \end{align*} $$ Then we have, with $z = -t D(g')$, $$\begin{align*} \frac{d^{n+1} y}{dx^{n+1}} &= (-1)^{n-1} t^{-1} \left((1-2n) t^{-2n} \phi_{n-1}(z) - t^{1-2n} t^{-1} z^2 \phi_{n-2} (z)\right)\\ &= (-1)^n t^{-1-2n} ((2n-1) \phi_{n-1}(z) + z^2 \phi_{n-2} (z)) \\ & = \frac{(-1)^n \phi_n (z)}{t^{2(n+1)-1}} , \end{align*}$$ since the reverse Bessel polynomials satisfy the recurrence $\phi_n (z) = (2n-1)\phi_{n-1}(z) + z^2 \phi_{n-2}(z)$.
Since the Bessel polynomials show up even in this simple case, it appears that the general case will have to include some generalization of the Bessel polynomials. In fact, for general $f'(t)$ the argument above goes through to show that the coefficients of the terms in the numerator of $\frac{d^n y}{dx^n}$ containing only powers of $f'(t)$ and $f''(t)$ and derivatives of $g(t)$ are the those of the reverse Bessel polynomials. What's remains, then, is to characterize the terms containing third and higher-order derivatives of $f$.
Glorfindel
  • 3,955
Mike Spivey
  • 55,550
I am not sure if what follows is useful for symbolic manipulations, but it is definitely useful for numerical evaluation of these derivatives.
First, let me state the "closed form" expression for $n^\text{th}$ derivative of $f^{-1}(x)$. Naturally, it is found by fiddling with $f(f^{-1}(x))=x$. Since the above is a composition, it is natural to expect appearance of Bell polynomials (see ref. by Paolo Ricci).
The derivation has been done by a trial and error:
$$ \frac{\mathrm{d}^n}{\mathrm{d} x^n} f^{-1}(x) = Y\left(\begin{array}{cc} \frac{(n)_1}{ f^{-1}(x)} & -\frac{ f^{(2)}( f^{-1}(x)) }{ 2 \left(f^{-1}(x)\right)^2 } \\ \frac{(n)_2}{ f^{-1}(x)} & -\frac{ f^{(3)}( f^{-1}(x)) }{ 3 \left(f^{-1}(x)\right)^3 } \\ \vdots & \vdots \\ \frac{(n)_{n-1}}{ f^{-1}(x)} & -\frac{ f^{(n)}( f^{-1}(x)) }{ n \left(f^{-1}(x)\right)^n } \end{array} \right) \qquad \qquad \text{for} \quad n \ge 2 $$
Or in Mathematica:
In[136]:= Table[
 With[{z = InverseFunction[f][x]},
  BellY[Table[{Pochhammer[n, j]/
       Derivative[1][f][
        z], -Derivative[j + 1][f][
         z]/((j + 1) Derivative[1][f][z]^(j + 1))}, {j, n - 1}]] -
    D[z, {x, n}] // Simplify], {n, 2, 6}]
Out[136]= {0, 0, 0, 0, 0}
Now, to answer your question, we write $y = g(f^{-1}(x))$, and apply another Bell polynomial for derivative of a composition:
In[137]:=
With[{p = 4, z = InverseFunction[f][x]},
  Sum[Derivative[m][g][z] BellY[p, m,
      Table[If[k == 1, 1/Derivative[1][f][z],
        BellY[Table[{Pochhammer[k, j]/
           Derivative[1][f][
           k - 1}]]], {k, p}]], {m, 1, p}] - (D[
     g[z], {x, p}])] // Expand
Out[137]= 0
Sasha
  • 70,631
  • Looks neat, but I was sorta kinda hoping for something entirely in terms of $f^{(k)}(x)$ and $g^{(k)}(x)$... – J. M. ain't a mathematician Oct 04 '11 at 14:59
  • You can replace Bell's $Y$-polynomial with it's sum representation, using: With[{n = 5}, Sum[n! y[Total[m]] Apply[Times, (Array[x, n]/Range[n]!)^m 1/m!], {m, FrobeniusSolve[Range[n], n]}] - BellY[Table[{y[k], x[k]}, {k, n}]]] – Sasha Oct 04 '11 at 15:19
  • Oh, I did have an inkling that Bell will be needed here; what I was considering was some expression with Bell polynomials and the derivatives of $f$ and $g$... – J. M. ain't a mathematician Oct 04 '11 at 15:24
