17
Let $G$ be an abelian group. Let $a, b \in G $ and let their order be $m$ and $n$ be respectively. Is it always true that order of $ab$ is $lcm(m,n)$?
What if $m$ and $n$ are coprime to each other?
Dietrich Burde
  • 130,978
ABC
  • 1,983
  • 29
    Certainly the order of $ab$ need not be the lcm. As a simple example, $a$ and $a^{-1}$ have the same order, but $a^{-1}a$ has very small order. – André Nicolas Sep 24 '11 at 13:56
When the group is finite and Abelian, you can show that if $d=\text{ord}(ab)$ where $m=\text{ord}(a)$ and $n=\text{ord}(b)$ then $$d \mid \frac{mn}{\gcd(m,n)}=\text{lcm}(m,n)$$ and $$\frac{mn}{\gcd(m,n)^2} \mid d.$$ ${}{}{}{}{}$ In particular this means that if $m$ and $n$ are coprime the order is multiplicative.
Mailbox
  • 896
Eric Naslund
  • 72,099
20
You can prove that "anything" could happen for the order of a product. In more precise words:
For any integers $m;n;r > 1$, there exists a finite group $G$ with elements $a$ and $b$ such that $a$ has order $m$, $b$ has order $n$, and $ab$ has order $r$.
For a beautiful proof, see Theorem 1.64 in http://www.jmilne.org/math/CourseNotes/GT.pdf
