24
Suppose $a$ and $b$ are elements of a group $G$. If $a^{-1}b^{2}a=b^{3}$ and $b^{-1}a^{2}b=a^{3}$, prove $a=e=b$.
I've been trying to prove but still inconclusive. Please prove to me. Thanks very much for proof.
Austin Mohr
  • 25,662
Aj I
  • 1,011
In fact, it is true that the presentation $$\langle a,b\ |\ a^{-1}b^na=b^{n+1}, b^{-1}a^nb=a^{n+1}\rangle$$ always defines the trivial group.
Here's a proof: Let $M=n^{n+1}$, $N=(n+1)^{n+1}$, and check that we have $b^{-(n+1)}a^Mb^{(n+1)}=a^N$.
Now we also know from the relations that $ab^{(n+1)}=b^na$ and similarly $b^{-(n+1)}a^{-1}=a^{-1}b^{-n}$. So we also have
$$\begin{align} a^N&=b^{-(n+1)}a^Mb^{(n+1)} \\ &=(b^{-(n+1)}a^{-1})a^M(ab^{(n+1)})\\ &=a^{-1}b^{-n}a^Mb^na. \end{align}$$
Thus $a^N=b^{-n}a^Mb^n=a^K$, where $K=n\cdot (n+1)^n$. So we have $1=a^{N-K}=a^L$, where $L=(n+1)^n$. But if $P=n^n$ (sorry for all the letters!), we have $b^{-n}a^Pb^n=a^L=1$, so $a^P=1$.
But $\gcd(P,L)=\gcd(n,n+1)=1$, so $a=1$, and of course this implies $b^n=b^{n+1}$, so also $b=1$.
Shaun
  • 44,997
  • @ Steve D: Thank you for a new proof. – Aj I Sep 22 '11 at 11:56
    +1 Easy for me to follow this argument :-) Probably well known? @Aj i: Again, just to make sure that you know. If you find Steve's answer more helpful than mine, you are welcome to accept his answer instead of mine. Strictly your call! This is very much in the spirit of the site. A common policy seems to be: 1) be generous with upvotes, but 2) it is usually a good idea to wait a bit for you to accept an answer. A better one may be coming up!! – Jyrki Lahtonen Sep 22 '11 at 12:12
  • @ Jyrki Lahtonen: Thank you for your good advice for a beginner. – Aj I Sep 22 '11 at 12:17
    @JyrkiLahtonen: It is an exercise in Cohen's Combinatorial Group Theory, somewhere in the first couple of chapters. I didn't remember all the details when I started writing, all I had in mind was "use that n+1 and n are rel. prime" :). –  Sep 22 '11 at 12:21
19
As it happens I have my copy of Baumslag & Chandler on the shelf. This exercise is listed as very hard. I seem to have pencilled in a solution 27-28 years ago. The text is really worn out, so I can only make out the first few steps. Damn, I really need a prescription for new glasses... Anyway here are the first three consequences of those relations: $$ a^{-1}b^8a=b^{12}, a^{-1}b^{12}a=b^{18}, a^{-1}b^{18}a=b^{27}. $$ As consequences of these I seem to have derived (you must rederive these for full credit) the following: $$ a^{-2}b^{12}a^2=b^{27}=a^{-3}b^8a^3=b^{-1}a^{-2}b^8a^2b. $$ The next consequence seems to be $a^{-2}b^8a^2=a^{-2}b^{12}a^2.$ From that point on the text is too blurred, but I think I might be able to redo that even though my brain has lost most of its agility over the years. Just in case this is homework I will stop here with these hints.
Jyrki Lahtonen
  • 133,153
  • Thanks very much for your advice. I'll try again from your instructions. – Aj I Sep 22 '11 at 06:41
  • @Aj i: Good luck! To derive the maximum benefit from these hints try to figure out, where this approach came from. I feel that I have, to a great extent, ruined this problem for you. Makes me a bit sad actually. – Jyrki Lahtonen Sep 22 '11 at 06:48
  • @ Jyrki Lahtonen:I'm trying, but it also proved unsuccessful. Do you have any suggestions for me? – Aj I Sep 22 '11 at 07:42
    @Aj i: Which of the above identities you had trouble with? May be you should try easier questions first. This is very hard. – Jyrki Lahtonen Sep 22 '11 at 08:05
  • @ Jyrki Lahtonen:Thank you very much. – Aj I Sep 22 '11 at 08:28
    @Aj i: You do know that conjugation by an element is an automorphism of the group, and maps powers to powers? That is the starting point. But only a starting point! – Jyrki Lahtonen Sep 22 '11 at 09:22
  • Please let me know about the conjugation and ways to prove. Thank you very much. – Aj I Sep 22 '11 at 09:42
    @Aj i: If $xyx^{-1}=z$, then $$z^k=(xyx^{-1})^k=(xyx^{-1})(xyx^{-1})\cdots(xyx^{-1})=xy^kx^{-1}.$$ – Jyrki Lahtonen Sep 22 '11 at 09:46
    In this time, we can prove that $b^{27}=a^{-2}b^{12}a^{2}=a^{-2}b^{8}a^{2}=b^{18}$, so $b^{9}=e$ and $b^{5}=e$. Hence $b=e$. Similarly, $a=e$. Thank you Jyrki Lahtonen. – Aj I Sep 22 '11 at 09:52
  • @ Jyrki Lahtonen:Thanks for your very valuable for me. I am sorry for my poor English. – Aj I Sep 22 '11 at 10:22
In this answer I give credit to Jyrki Lahtonen for the answer he posted.
There are holes in his post, so I sensed the need for a step by step answer (firstly to convince myself, but also other people in doubt), and so here it is.
$\bbox[5px,border:2px solid]{\begin{array}{cc}a^3=b^{-1}a^2b&(\alpha)\\b^3=a^{-1}b^2a &(\beta)\end{array}}$
$b^{6}=b^3b^3=(a^{-1}b^2a)(a^{-1}b^2a)=a^{-1}b^4a\quad(\alpha)$
$b^{12}=b^6b^6=(a^{-1}b^4a)(a^{-1}b^4a)=a^{-1}b^8a\quad(\alpha)$
$b^{18}=b^{12}b^6=(a^{-1}b^8a)(a^{-1}b^4a)=a^{-1}b^{12}a\quad(\alpha)$
$b^{27}=b^{18}b^6b^3=(a^{-1}b^{12}a)(a^{-1}b^4a)(a^{-1}b^2a)=a^{-1}b^{18}a\quad(\alpha)$
$b^{27}=a^{-1}b^{18}a=a^{-2}b^{12}a^2=a^{-3}b^8a^3=\ (\beta)\ =(b^{-1}a^2b)^{-1}b^8(b^{-1}a^2b)=(b^{-1}a^{-2}b)b^8(b^{-1}b^{-1}a^2b)=b^{-1}a^{-2}b^8a^2b=b^{-1}(a^{-1}(a^{-1}b^8a)a)b=b^{-1}(b^{18})b=b^{18}$
$b^{27}=b^{18}\Rightarrow b^9=1$
$b^9=b^3b^3b^3=(a^{-1}b^2a)(a^{-1}b^2a)(a^{-1}b^2a)=(a^{-1}b^6a)=1\Rightarrow b^6=1\quad (\beta)$
$b^3=b^9b^{-6}=1=a^{-1}b^2a\Rightarrow b^2=1$
$b=b^3b^{-2}=1$ and then $a^3=b^{-1}a^2b=a^2\Rightarrow a=1\quad (\alpha)$.
$\bbox[5px,border:2px solid]{a=b=1}$
zwim
  • 28,563
Another way. $$b^2a=ab^3,$$ which gives $$b^2ab^{-2}=ab$$ and we obtain: $$b^2a^3b^{-2}=(ab)^3$$ and from here $$b^2(b^{-1}a^2b)b^{-2}=(ab)^3$$ or $$ba^2b^{-1}=(ab)^3.$$ Also, $$b^2a^2b^{-2}=(ab)^2,$$ which gives $$a^2=b^{-2}(ab)^2b^2$$ and we obtain: $$b\left(b^{-2}(ab)^2b^2\right)b^{-1}=(ab)^3$$ or $$b^{-1}(ab)^2b=(ab)^3$$ or $$(ab)^2=(ba)^3.$$ Similarly, $$(ba)^2=(ab)^3,$$ which gives $$(ab)^2=(ba)(ab)^3$$ or $$ba^2b=e.$$ Similarly, $$ab^2a=e.$$ Now, since $$a^{-1}b^2a=b^3,$$ we obtain $$a^2b^3=e.$$ In another hand, $$ab^2a=e$$ gives $$b^2=a^{-2}$$ and $$a^2b^2=e.$$ Id est, $$e=a^2b^3=eb=b,$$ $$a=e$$ and we are done!
