Find the maximum and minimum distances from the origin to the curve $5x^3+6xy+5y^2-8=0$
My attempt:
We have to maximise and minimise the following function $x^2+y^2$ with the constraint that $5x^3+6xy+5y^2-8=0$.
Let $$F(x,y)=x^2+y^2+\lambda(5x^2+6xy+5y^2-8)$$ $$\frac{\delta F(x,y)}{\delta x}=2x+\lambda(10x+6y)$$ and $$\frac{\delta F(x,y)}{\delta y}=2y+\lambda(6x+10y)$$ Multiplying the 2 equations by y,x respectively and subtracting I get $$\lambda(y^2-x^2)=0$$ Hence $$y=x$$ Substituting $x=y$ in $5x^3+6xy+5y^2-8=0$, I get the $x=\pm \frac{1}{\sqrt2}$ and $y=\pm \frac{1}{\sqrt2}$ . Now I am stuck. Both the points corresponds to only one distance. Did I do something wrong?
