Let $f(x)=1/x$. Show continuity at $x=1/2$
My work:
$$\left| {x - \frac{1}{2}} \right| < \delta \Rightarrow \left| {\frac{1}{x} - 2} \right| < \varepsilon $$
$$\left| {\frac{1}{x} - 2} \right| = \left| {\frac{2}{x}\left( {\frac{1}{2} - x} \right)} \right| = \left| {\frac{2}{x}} \right|\left| {\left( {\frac{1}{2} - x} \right)} \right|$$
Now, I'm not sure how to choose $\delta$ properly. How to do it?
You can divide your tasks in smaller tasks:
Task 1: $x \ge \frac{1}{2}$. Then $f(x) \le 2$, so you get rid of the $“|”$ and may find a $\delta_1$.
Task 2: Do the same for $x \lt \frac{1}{2}$, which gives you a $\delta_2$.
Then $\delta := \min\{\delta_1,\delta_2\}$ will do the job for your original problem.
Keba
  • 2,485
  • 28
If you make sure that $\delta$ is not greater than $0.1$, then $|x-0.5|<\delta$ implies a lower bound of $0.4$ on $x$. Thus, $\dfrac2{x}$ cannot be greater than $\dfrac2{0.4}=5$. Can you take it from here?
Alraxite
  • 5,647
First of all, let's make sure that $|1/x|$ is not too big. So choose $\delta\le \frac{1}{4}$. Then $\frac{1}{4}\le x\le \frac{3}{4}$, and therefore in particular $0\lt \frac{1}{x}\le 4$.
Thus your expression has absolute value $\le 8\left|x-\frac{1}{2}\right|$.
If additionally we make $0\lt \delta \lt \frac{\epsilon}{8}$, then we will be OK.
Putting things together, we choose $\delta$ positive and equal to the smaller of $\frac{1}{4}$ and $\frac{8}{\epsilon}$.
André Nicolas
  • 507,029
  • Thanks, but how did you know how choose $\delta$ properly? What would be a "bad" $\delta$ in that case? I think the counter-example would make it easier for me to understand – SuperStamp Jan 22 '14 at 20:31
    The only problem that arises is if the $\epsilon$ we are given is kind of big. For example, we must not come to the conclusion that $\delta=\frac{\epsilon}{100}$ is good enough. For if $\epsilon=100$, that lets $x$ be $0$, and then the inequality you used is not helpful, since $|1/x|$ can be very big. More geometrically, we first of all need to make sure that $\delta$ is small enough that we have some control ovewr the $\frac{2}{x}$ term of your expression. This issue comes up in many $\epsilon$-$\delta$ calculations. – André Nicolas Jan 22 '14 at 20:38
