I've just seen that LaTeX offers at least three symbols for denoting angles:
$\text{\sphericalangle}:\sphericalangle ABC \\\text{\measuredangle}:\measuredangle ABC\\\text{\angle}: \angle ABC$
I think I've understood that a spherical angle is something different than an angle in euclidean geometry.
So I have some questions to the notation of angles:
  • What is the semantic difference of $\angle ABC$ and $\measuredangle ABC$?
  • Which symbol is commonly used in literature? Please note:
    • The symbol might be not in the list from above
    • I know this is a loose quesiton. Please give at least one book that makes use of the notation you think is most common. (e.g. these German lecture notes make use of $\angle$ and $\sphericalangle$. The difference seems to be that $\measuredangle$ is the size of the angle whereas $\angle$ denotes the angle itself. So when I understand it correctly, in a rectangle ABCD you could say: $\sphericalangle ABC = \sphericalangle BCD$ and $\angle ABC \neq \angle BCD$)
    • If there is a "mathematical style guide" that makes notes which notation to use for angles it would be an answer I'd appreciate very much!
  • Are there differences in German mathematics / English mathematics? E.g. just like I think Americans write $1/4$ rather than $\frac{1}{4}$ in contrast to Germans.
(I would also like to know what you think which symbol I should use for angles in euclidean geometry. How well known is the difference of these notations? So, do you think the choice of symbol matters?)
Martin Thoma
  • 9,821
  • See also this question: https://tex.stackexchange.com/questions/154437/angle-symbols-in-latex – EthanAlvaree Apr 23 '19 at 21:33
  • More important than the used symbols are the various ideas of angles. See, e.g., here: https://math.stackexchange.com/questions/583066/what-is-the-exact-and-precise-definition-of-an-angle/583119#583119 – Christian Blatter May 23 '19 at 15:02
I think there is no definite standard: every author uses the symbol he/she prefers and this varies with time and with place.
In Italy, for instance, the widespread notation for angle $ABC$ is $A\hat{B}C$.
Marvin Jay Greenberg in his "Euclidean and non-Euclidean geometries" (1974) uses instead $\sphericalangle ABC$.
And I could go on with a lengthy list of different examples.
Intelligenti pauca
  • 50,470
  • 42
  • 77
