13
I tried to integrate $x e^x \sin x$, using integration by parts, and setting $\frac{\, \mathrm dv}{\, \mathrm dx} = e^x \sin x$. Even though I got really close, I kept getting it wrong. Can someone please solve it with working out? Thanks in advance.
**********EDIT***** I have found the answer, all thanks to those who contributed :) I don't know if I could of connected the answer here but I just posted it below, thank you all again!
Tesla
  • 1,380
Sam Chahine
  • 1,302
  • 28
  • this aint that straight forward. – Lost1 Jan 13 '14 at 11:07
  • Im not sure if you can read my writing but i think i got pretty close to the answer "wolframalpha", @Lost1. http://fluorine-silver.blogspot.com.au/2014/01/math-so-damn-close.html – Sam Chahine Jan 13 '14 at 11:11
  • i dont understand your v and v'. this question is such a pain in the arse if you don't use the hint Nigel posted, but needs complex numbers. I wanted to post a solution using elementary integration and i got stuck... – Lost1 Jan 13 '14 at 11:14
  • Related : http://math.stackexchange.com/questions/540295/integrate-eax-sinbx – lab bhattacharjee Jan 13 '14 at 11:15
  • V = f(x), v'=f'(x), complex numbers is a year 12 extension 2 topic, I just finished year 10, but this question has destroyed me for the last 2 days, what else do I need to learn to solve this problem? I thought you could do it just making 2 things one product then integrating to get f'(x) @Lost1 – Sam Chahine Jan 13 '14 at 11:16
    There is no such thing as a "three product". The function $x\mapsto x\mathrm e^x\sin x$ is a function, dot. You could write it as well $2\sqrt x\left(\mathrm e^{x/2}\right)^2\sqrt x\sin(x/2)\cos(x/2)$ and it would be a six function... – Tom-Tom Jan 13 '14 at 16:53
6 Answers6
16
If you don't want to try with complex calculus, you might use this:
Let's define $g(x) = e^x \sin{x} $, so we have: $J = \int x g(x) \, dx$.
Then, if you use chain rule, you will have:
$$J = x\, \int g(x) \, dx - \iint g(x) \, dx^2, $$
where, using again the chain rule:
$$\int g(x) \, dx = \int e^x \sin{x} \, dx = \frac{e^x}{2} (\sin{x} - \cos{x})$$
Thus:
$$\iint g(x) dx^2 = \int \frac{e^x}{2} (\sin{x} - \cos{x}) \, dx $$
where the first integral has already been computed. Using again the chain rule for the cosine integral, it finally yields:
$$\large{ \color{blue}{ J = \frac{x}{2} e^x (\sin{x} - \cos{x} ) + \frac{e^x}{2} \cos{x} } }$$
Do not forget the integration constant! Cheers.
Dmoreno
  • 7,517
One general idea with products of three functions is to use the product rule in the form $$ (u v w)' = u' v w + u v' w + uv w' $$ and the get partial integration in the form $$ \int u' v w = uvw - \int u v' w - \int uv w' $$ and then the solution of your problem is straightforward but tedious.
After two applications of above rule (with $u=e^x$) and some reorganization you find
$$ 2 \int x e^x \sin x \, dx = xe^x \sin x - x e^x \cos x -\int e^x \sin x \, dx + \int e^x \cos x \, dx $$ and the rest is easy.
Let me elaborate on Nigel's hint, and btw he meant $e^{ix} = i \sin x +\cos x$. There is no $\pi$.
then the integral you want is J. define the integral $I = \int x \cos x e^x \text{d}x$.
Then $I + iJ = \int x e^{ix}e^x \text{d}x = \int xe^{(i+1)x}\text{d}x$
note $i$ is square root of minus one, so it i just a constant, you integrate this by part and seperate out real and imaginary part. The imaginary part is what you want.
At first I wanted to post this, but I guessed this is not what OP wanted.
however, without this, this integral is a pain in the backside...
Lost1
  • 7,895
Hint, using complex numbers: $$ \sin(\theta) = \frac{ e^{i\theta} - e^{-i \theta} }{2i} $$
Without complex numbers: Let $f = x$, $g' = e^x \sin x$.
First we calculate $g = \int g' dx$ by integration by parts: $$ \begin{array}{c} I = \int {{e^{ax}}\sin (bx)dx} = \left[ {\begin{array}{*{20}{c}} {u = \sin (bx)}&{v' = {e^{ax}}}\\ {u' = b\cos (bx)}&{v = {e^{ax}}/a} \end{array}} \right]\mathop = \limits^{{\mathop{\rm int}} } \frac{{{e^{ax}}\sin (bx)}}{a} - \int {b\cos (bx)\frac{{{e^{ax}}}}{a}dx} \\ = \frac{{{e^{ax}}\sin (bx)}}{a} - \frac{b}{a}\int {\cos (bx){e^{ax}}dx} = \\ = \left[ {\begin{array}{*{20}{c}} {f = \cos (bx)}&{g' = {e^{ax}}}\\ {f' = - b\sin (bx)}&{g = {e^{ax}}/a} \end{array}} \right] = \frac{{{e^{ax}}\sin (bx)}}{a} - \frac{b}{a}\left( {\frac{{\cos (bx){e^{ax}}}}{a} - \frac{{ - b}}{a}\int {\sin (bx){e^{ax}}dx} } \right) = \\ = \frac{{{e^{ax}}\sin (bx)}}{a} - \frac{{b\cos (bx){e^{ax}}}}{{{a^2}}} - \frac{{{b^2}}}{{{a^2}}}\int {\sin (bx){e^{ax}}dx} = \frac{{{e^{ax}}\sin (bx)}}{a} - \frac{{b\cos (bx){e^{ax}}}}{{{a^2}}} - \frac{{{b^2}}}{{{a^2}}}I \end{array}$$ Thus $$ I = \frac{{{e^{ax}}\sin (bx)}}{a} - \frac{{b\cos (bx){e^{ax}}}}{{{a^2}}} - \frac{{{b^2}}}{{{a^2}}}I$$ Solving for $I$, we get $$ I = \frac{{{e^{ax}}\left( {a\sin (bx) - b\cos (bx)} \right)}}{{{a^2} + {b^2}}} + C $$ so $$ g(x) = \frac{{{e^{x}}\left( {\sin (x) -\cos (x)} \right)}}{{2}} \ . $$
Thus, to solve the big integral we do again integration by parts with $f=x$: $$ \int f g' = fg - \int f' g = x \frac{{{e^{x}}\left( {\sin (x) -\cos (x)} \right)}}{{2}} - \int \left( \frac{{{e^{x}}\left( {\sin (x) -\cos (x)} \right)}}{{2}} \right) dx $$ where the last integral can be calculated as above.
onepound
  • 1,365
LinAlgMan
  • 2,924
Hint: $$\sin(\theta)= Im (e^{i \theta})$$ Then use integration by parts.
$$\int e^x\sin(x)\ dx = \frac{1}{2}e^x(\sin x-\cos x) + C $$
$$ \int e^x\cos(x)\ dx = \frac{1}{2}e^x(\sin x +\cos x ) + C $$
$$ u = x \\ u'= 1\\\\v'=e^x\sin(x) \\v= \frac{1}{2}e^x(\sin x -\cos x) + C \\ I = \frac{xe^x}{2}(\sin x-\cos x )-\frac{1}{2} \int e^x(\sin x-\cos x) + C \\ \text{Let }Z^- = \sin x -\cos x \\ \text{and}\\ \text{Let }Z^+ = \sin x+\cos x \\ \frac {xe^x}{2}(Z^-) - \frac{1}{2}\left(\frac{1}{2}e^x(Z^- - Z^+)\right) +C\\ \frac {xe^x}{2}(\sin x-\cos x) - \frac{1}{2}\left(\frac{1}{2}e^x(-2\cos x )\right)+C\\ \frac {xe^x}{2}(\sin x-\cos x) + \frac{1}{2}e^x(\cos x) + C\\ \int xe^x\cos x\ dx = \frac{1}{2}e^x(x\sin x-x\cos x+\cos x) + C $$ Well. I told you guys I would do it, thank you all for your help, turn out I've been stuck on this bastard for 3 days not two, time flies when you're having fun! ;) - I entered most of the steps, you guys should see the gaps if there are any, and i'm sorry my MathJax isn't perfect, this is my first time using it for such a big equation, thank you all again! Next stop, five function ;) (I checked on wolframalpha.com, got the same answer!)
JMCF125
  • 2,738
  • 34
Sam Chahine
  • 1,302
  • 28
