The statement is true.
Given $g(x)$ everywhere differentiable and $f(x)$ continuous real to real functions defined for all $x$ real numbers.
If $f(x_i)\neq 0$, $g'(x_i)=0$ for any $x_i$ that satisfies $g(x_i)=0$ then $\int_{-\infty}^{\infty} f(x) \delta(g(x)) dx $ diverges. The converse is true in a restricted sense: if $f(x_i)\neq 0$, $g'(x_i)\neq 0$ for all $x_i$ that satisfies $g(x_i)=0$ and if there are only finitely many such $x_i$ points then $\int_{-\infty}^{\infty} f(x) \delta(g(x)) dx $ is finite.
The support of the delta function is the infinitesimal neighborhood around $0$, thus we can restrict the integral to the open sets around $x_i$, label them $U_i$.
Consider first the case where $g(.)$ is monotonic around $x_i$. Then there exists an inverse function of $g$ for which $G_i(g(x)) = x$ for $x\in U_i$. Furthermore the image of the open set by a continuous function is an open set, label it $V_i = g[U_i]$.
Then you can write
$$\int_{-\infty}^{\infty} f(x) \delta(g(x)) dx
=\sum_i \int_{U_i} f(x) \delta(g(x)) dx
=\sum_i \int_{V_i} f(G_i(g)) \delta(g) \frac{dG_i}{dg} dg\,.$$
Let us denote $G'_i = \frac{dG_i}{dg}$.
From the definition of the delta function
$$\sum_i \int_{V_i} f(G_i(g)) G'_i(g) \delta(g) dg = \sum_i f(G_i(0)) G'_i(0)$$.
Thus if $f(x_i) = f(G_i(0)) \neq 0$ then this is finite iff $G'_i(0)$ is finite. However $G'_i(0) = 1/g'(x_i)$ from the inverse function theorem, therefore the expression is finite exactly if $g'(x_i)\neq 0$.
The case where $g(.)$ has a local maximum or minimum at some $x_i$ is a bit more subtle. In this case, there is no inverse, and the previous argument is not applicable. Let us consider the case where $g(.)$ is at least $n$ times differentiable, such that if it has a minimum, $g(x) \rightarrow a x^{2n}$ in an infinitesimal neighborhood $U_i$, where $a> 0$ real and $n\geq 1$ integer. The delta function can be represented formally as the limit of the series $\phi(x) = (2\pi \sigma^2)^{-1/2}\exp(-x^2/2\sigma^2)$ where $\sigma\rightarrow 0$. Then
$$\int_{U_i} f(x) \delta(g(x)) dx = \lim_{\sigma\rightarrow 0}\int_{U_i-x_i}\frac{1}{\sqrt{2\pi \sigma^2}} f(x_i + z)\exp(-z^{4n}/2\sigma^2) dz\,. $$
Since $f(.)$ is continuous you can always find a $c$ in a sufficiently small neighborhood that $f(x_i)+c>f(x)> f(x_i)-c$. Thus we can give a upper/lower bound on the integral by replacing $f(x_i+z)$ with $f(x_i)\pm c$, which you can take out in front of the integral. Now you can show that
$$\frac{1}{\sqrt{2\pi \sigma^2}} \int_{-\infty}^{\infty} \exp(-x^{2n}/2\sigma^{2}) dx
=\sigma^{(1-n)/n}\times\frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} \exp(-y^{2n}/2) dy
The second term is finite in the limit $\sigma \rightarrow 0$, so this is asymptotically proportional to $\sigma^{(1-n)/n}$. In the limit $\sigma\rightarrow 0$, this goes to infinity. Since, the lower bound of the integral goes to infinity, the integral is divergent.
