Stuck in this problem for quite a while. Anyone can offer some help? The problem is as follows:
Fred has $5000 to invest over the next five years. At the beginning of each year he can invest money in one- or two-year time deposits. The bank pays 4% interest on one-year time deposits and 9 percent (total) on two-year time deposits. In addition, West World Limited will offer three-year certificates starting at the beginning of the second year.These certificates will return 15% (total). If Fred reinvest his money that is available every year, formulate a linear program to show him how to maximize his total cash on hand at the end of the fifth year.
zf xiao
  • 61
  • I can solve it with brute-force by considering every invest possibility at the beginning of each year. But how to solve it as linear programming? I have trouble in modeling the problem. – zf xiao Sep 07 '11 at 12:18
  • Is there any cost to 3-year certificate ? –  Sep 07 '11 at 13:23
  • I don't think there is. The only condition is the three-year certificate starts at the beginning of the 2nd year. – zf xiao Sep 07 '11 at 13:41
  • yes but you see the pattern,no?. Is it a compound interest or is the money fixed ? Does it only depend on the money Fred has initially at the beginning of the 2nd year? Then we go for a one year and obtain %4 anyhow, to get the max out of the 3-year thing. –  Sep 07 '11 at 14:12
  • My understanding is it's a compound interest. For example, if Fred goes for a one year at the beginning of the first year. then he has 5000(1+4%) available for investment at the beginning of the 2nd year. The problem is he has multiple options in each year. And the available money depends on his previous investments... so I was trapped. – zf xiao Sep 07 '11 at 14:28
  • I see the difficulty because although it seems like a continuous process this is a discrete time problem. So time is not an issue. it is only a matter of 5 steps that the revenue is maximized in. –  Sep 07 '11 at 14:52
Notice that Fred can always invest in 1-year deposits and get this money at the beginning of the next year for further investments. This means that all available money will always be invested and we do not bother about the rest.
Year 1: invest $ x_1 $ in 1-year deposit $ 4\% $, $ x_2 $ in 2-year $ 9\% $
  • $ x_1 + x_2 \leq 5000 $ (= available money)
Year 2: invest $ x_3 $ in 1-year $ 4\% $, $ x_4 $ in 2-year $ 9\% $, $ x_5 $ in 3-year $ 15\% $
  • $ x_3 + x_4 + x_5 \leq 1.04 \times x_1 $ (= available money)
Year 3: invest $ x_6 $ in 1-year $ 4\% $, $ x_7 $ in 2-year $ 9\% $, $ x_8 $ in 3-year $ 15\% $
  • $ x_6 + x_7 + x_8 \leq 1.04 \times x_3 + 1.09 \times x_2 $ (= available money)
Year 4: invest $ x_9 $ in 1-year $ 4\% $, $ x_{10} $ in 2-year $ 9\% $
  • $ x_9 + x_{10} \leq 1.04 \times x_6 + 1.09 \times x_4 $ (= available money)
Year 5: invest $ x_{11} $ in 1-year $ 4\% $
  • $ x_{11} \leq 1.04 \times x_9 + 1.09 \times x_7 + 1.15 \times x_5 $ (= available money)
Year 6:
  • available money = $ 1.04 \times x_{11} + 1.09 \times x_{10} + 1.15 \times x_8 $ = final cash = maximize !
So, if I did not make a mistake, there are 11 unknowns x1, ..., x11 for the individual investments, 5 linear inequalities (1) - (5), and one linear goal function (6) to be maximized. This linear programming problem can be solved by the simplex algorithm.
ADDED (based on Mike's comment): for completeness the 11 inequalities xi >= 0 for the unknowns should be added.
Jiri Kriz
  • 2,087
    Looks good to me, although you might want to throw in the nonnegativity constraints for completeness. – Mike Spivey Sep 07 '11 at 16:15
  • @Mike: added. Thanks! – Jiri Kriz Sep 07 '11 at 16:23
  • This formulation makes the implicit assumption that all money available at the beginning of each year should be immediately reinvested. This assumption is justified in this case because there is a one-year investment option, but it does not hold in general. – Fabio Somenzi Oct 21 '17 at 17:24
This is how i coded it in CPLEX. If it may help.
     * OPL 12.6.1.0 Model
     * Author: shokirovn
 // decision variables
 // x(ij) = amount of money invested in period i for j years i = 1,...,5 and j = 1,2,3.
 // for j = 1 year
 dvar float+ x11;
 dvar float+ x21;
 dvar float+ x31;
 dvar float+ x41;
 dvar float+ x51;
 // for j = 2 years
 dvar float+ x12;
 dvar float+ x22;
 dvar float+ x32;
 dvar float+ x42;
 // for special certificate j = 3
 dvar float+ x23;
 dvar float+ x33;
 // expressions
 dexpr float profit = 1.15*x33 + 1.09*x42 + 1.04*x51;
 // model
 maximize profit;
 subject to {
        // investment should not exceed available money in year i.
        x11 + x12 <= 5000;
        x21 + x22 + x23 <= 1.04*x11;
        x31 + x32 + x33 <= 1.09*x12 + 1.04*x21;
        x41 + x42 <= 1.09*x22 + 1.4*x31;
        x51 <= 1.15*x33 + 1.09*x32 + 1.04*x41;
**OUTPUT:**
// Condition number of unscaled basis = 1.1e+001
x33 = 5450;
x42 = 0;
x51 = 6267.5;
x11 = 0;
x12 = 5000;
x21 = 0;
x22 = 0;
x23 = 0;
x31 = 0;
x32 = 0;
x41 = 0;
sh.n
I came up with a bit different model that I think it's more compact. I know it's been some years since this question was made, but please, someone let me know if it's not correct:
Being $ x_{ij} $ the amount invested in option i at year j, we look to
maximize $ z $ = 1,04$x_{15}$ + 1,09$x_{24}$ + 1,15$x_{33}$,
subject to:
  • $ x_{11} $ + $x_{12}$ <= 5000
  • $ x_{31} $ = $x_{34}$ = $x_{35}$ = 0
  • $ x_{12} $ + $x_{22}$ + $x_{32}$ <= 1,04 $x_{11}$
  • $ x_{13} $ + $x_{23}$ + $x_{33}$ <= 1,04 $x_{12}$ + 1,09 $x_{21}$
  • $ x_{14} $ + $x_{24}$ <= 1,04 $x_{13}$ + 1,09 $x_{22}$
  • $ x_{15} $ <= 1,04 $x_{14}$ + 1,09 $x_{23}$ + 1,15 $x_{32}$
  • $ x_{ij} $ >= 0
Does it make sense?
gcolucci
  • 375
