While doing my homework i find out that the maximum order of an element in $S_3$ is 3 (the element $(123)$) and the maximum order of an element in $S_4$ is 4 (the element $(1234)$)
Can i generalize that and say that the maximum order of an element in $S_n$ is n?
aviadch
  • 255
  • Check $S_5$ and see. – vadim123 Dec 30 '13 at 16:27
  • i asked to check if there is any theorem that prove what i wrote – aviadch Dec 30 '13 at 16:30
    What you wrote isn't true; you need only look at $S_5$ for a counterexample. – vadim123 Dec 30 '13 at 16:30
  • What vadim writes is accurate, @AviadChmelnik : before asking questions it is worthwhile to really try by yourself, for example by trying a decent ammount of examples. As he tells you,in $;S_5;$ you already have acounter example as the element $;(12)(345);$ has order $;6>5$, and in $;S_8;$ you already have elements of order $;15;$ , say... – DonAntonio Dec 30 '13 at 16:38
Well after checking $S_5$ i saw that what i said is not correct: element $(123)(45)$ has order of 6. thanks @vadim123
aviadch
  • 255
In general, you have to look at disjoint cycle types and hence for a "maximum" partition of $n=a_1 + \dots a_k$ and take the lcm of the $a_i$'s. Example for $S_7$: $7=2+5$ gives you order $10$ but $7=3+4$ yields $12$.
Nicky Hekster
  • 49,281
Your answer is here.
The maximum order of an element of finite symmetric group by William Miller, American mathematical monthly, page 497-506.
Bobby
  • 7,396
