Let us prove the following theorem by using pigeonhole principle.
Theorem: If you place $1,2,\cdots, n^2+1$ in a row in arbitrary order, then there exists a monotonic(increasing or decreasing) sequence with length equal to or more than $n+1$.
Proof : Let $a_1,a_2,\cdots,a_{n^2+1}$ be the numbers in a row. Also, let $inc[i]$ be the length of the maximum increasing sequence from $a_i$, and let $dec[i]$ be the length of the maximum decreasing sequence from $a_i$.
Then, for $i=1,2,\cdots, n^2+1$, let us consider the lattice point $(inc[i],dec[i])$. If either $inc[i]$ or $dec[i]$ is equal to or more than $n+1$, then we are happy. So, let us suppose this situation does not happen.
Then, since $n^2+1$ points are set in the $n^2$ points from $(1,1)$ to $(n,n)$, by pigeonhole principle, there exists at least one pair of distinct integers $i,j$ such that
$$(inc[i],dec[i])=(inc[j],dec[j])$$
However, this never happens. This is because if $i\lt j$, then either $a_i\lt a_j$ or $a_i\gt a_j$ holds. The former leas $inc[i]\lt inc[j]$, the latter leads $dec[i]\gt dec[j].$ Then, we now know the supposition leads a contradiction.
Hence, we now know that either $inc[i]$ or $dec[i]$ is equal to or more than $n+1$. This is what we have to show. Q.E.D.
