The gist of the answer is that with every small but certain step
the problem is simplified a little bit, hoping that in the end
all of these steps together will lead to full comprehension.
Disclaimer: I think the proof is not yet completed by taking together all steps.
Step 1.The whole problem is invariant for cyclic permutations.
Hence indeed, you cannot suppose without loss of generality that
$a \le b \le c \le d \le e$, but you can suppose without
loss of generality that $a$ is the smallest number and then
investigate the remaining permutations, giving the following
list of possibilities.
|a-b|,|b-c|,|c-d|,|d-e|,|e-a|
a ≤ b ≤ c ≤ d ≤ e 1 1 1 1 4
a ≤ b ≤ c ≤ e ≤ d 1 1 2 1 3
a ≤ b ≤ d ≤ c ≤ e 1 2 1 2 4
a ≤ b ≤ d ≤ e ≤ c 1 3 2 1 3
a ≤ b ≤ e ≤ c ≤ d 1 2 1 2 2
a ≤ b ≤ e ≤ d ≤ c 1 3 1 1 2
a ≤ c ≤ b ≤ d ≤ e 2 1 2 1 4
a ≤ c ≤ b ≤ e ≤ d 2 1 3 1 3
a ≤ c ≤ d ≤ b ≤ e 3 2 1 2 4
a ≤ c ≤ d ≤ e ≤ b 4 3 1 1 3
a ≤ c ≤ e ≤ b ≤ d 3 2 3 2 2 !(1)
a ≤ c ≤ e ≤ d ≤ b 4 3 2 1 2
a ≤ d ≤ b ≤ c ≤ e 2 1 2 3 4
a ≤ d ≤ b ≤ e ≤ c 2 2 3 2 3 !(2)
a ≤ d ≤ c ≤ b ≤ e 3 1 1 3 4
a ≤ d ≤ c ≤ e ≤ b 4 2 1 2 3
a ≤ d ≤ e ≤ b ≤ c 3 1 3 1 2
a ≤ d ≤ e ≤ c ≤ b 4 1 2 1 2
a ≤ e ≤ b ≤ c ≤ d 2 1 1 3 1
a ≤ e ≤ b ≤ d ≤ c 2 2 1 2 1
a ≤ e ≤ c ≤ b ≤ d 3 1 2 3 1
a ≤ e ≤ c ≤ d ≤ b 4 2 1 2 1
a ≤ e ≤ d ≤ b ≤ c 3 1 2 1 1
a ≤ e ≤ d ≤ c ≤ b 4 1 1 1 1
The numbers on the right are not so much the sizes of the intervals but
they indicate how many intervals ( bounded by $a,b,c,d,e$ ) are in between
( if you understand what I mean ) . The two orderings marked with an exclamation
sign (!) are the most promising, because the intervals to be minimized each
contain at least two other intervals, which, so to speak, makes it more
difficult to minimize them. The latter is desirable because what we seek
in the end is a maximum.
Also note that the problem is invariant for reversal of the ordering.
For example $a \le b \le c \le d \le e$ is the same as $a \ge b \ge c \ge
d \ge e$ . Thus we see e.g. that the ordering assumed in the question is
the one indicated as (1). There is more. If the order of (2) is reversed,
then we get: $c \le e \le b \le d \le a$ . A cyclic permutation then
gives: $a \le c \le e \le b \le d$ . Which is exactly case (1) again.
We conclude that (1) is the only case we have to investigate, in
the end. Thus, with no loss of generality: $$ a \le c \le e \le b \le d $$
Now take a look at the minmax function again. The arguments that have no
chance to be minimal can be removed. Also note the disappearance of the
absolute values:
A=\max{\left(\min{\left(|a-b|,|b-c|,|c-d|,|d-e|,|e-a|\right)}\right)} \qquad
\Longleftrightarrow \qquad
A=\max{\left(\min{\left(b-c,d-e,e-a\right)}\right)}
Step 2.
Further information about the magnitude of the numbers can be obtained
as follows. Let the numbers be diminished with an amount $\mu$ :
W(\mu) = (a-\mu)^2 + (b-\mu)^2 + (c-\mu)^2 + (d-\mu)^2 + (e-\mu)^2
It is desirable that $W$ is minimal as a function of $\mu$ because that gives
the least possible restriction on $(a,b,c,d,e)$ when $a^2+b^2+c^2+d^2+e^2 = 1$ .
Differentiating gives, not much to our surprise, that the minimum of $W(\mu)$
is obtained for:
\frac{1}{2} \frac{d W}{d \mu} = a + b + c + d + e - 5 \mu = 0
\qquad \Longrightarrow \qquad \mu = \frac{a + b + c + d + e}{5}
\qquad \Longrightarrow \qquad W(\mu) = a^2+b^2+c^2+d^2+e^2 - 5 \mu^2
Thus, with no loss of generality, we can - and we must - choose our numbers
$\; (a,b,c,d,e)$ , such that $a + b + c + d + e = 0$ . All choices in the
question and the given answers and comments fulfill this condition,
whether that is by coincidence or not ( I think not ).
Step 3.
According to the above, the minmax function can now be split into three pieces:
(d-e \ge e-a \ge b-c) \vee (e-a \ge d-e \ge b-c)
\quad \Longrightarrow \quad A = \max{(b-c)} \\
(d-e \ge b-c \ge e-a) \vee (b-c \ge d-e \ge e-a)
\quad \Longrightarrow \quad A = \max{(e-a)} \\
(e-a \ge b-c \ge d-e) \vee (b-c \ge e-a \ge d-e)
\quad \Longrightarrow \quad A = \max{(d-e)}
It is suggested herewith that we should anyway investigate
the special case, where none of the intervals is the smallest:
e-a = d-e = b-c
Because only differences of the numbers $\; (a,b,c,d,e) \;$ are considered in the
minmax function, there is still a degree of freedom in our problem, which is
the choice of the origin. Therefore we shall assume in the sequel that $\; e = 0$ .
As far as the special case is considered, we are almost there:
-a = d = b-c \quad \Longrightarrow \quad a+b+c+d+e = b+c = 0
\quad \Longrightarrow \\
c = -b \quad ; \quad d = 2 b \quad ; \quad a = - 2 b
Giving:
a^2+b^2+c^2+d^2+e^2 = 2(2b)^2 + 2b^2 = 1
\quad \Longrightarrow \quad b = \frac{1}{\sqrt{10}}
\quad \Longrightarrow \quad (a,b,c,d,e) = \frac{1}{\sqrt{10}} (-2,+1,-1,+2,0)
\quad \Longrightarrow \quad A = \frac{2}{\sqrt{10}}
Which is exactly the solution as given in the question.
But why would
the special case give the solution?
Step 4.
Let's try to make a small modification of the special case, as follows.
a = -d = \lambda (b-c) \quad \Longrightarrow \quad
c = -b \quad ; \quad d = 2 b \lambda \quad ; \quad a = - 2 b \lambda
Giving:
a^2+b^2+c^2+d^2+e^2 = 2(2b \lambda)^2 + 2 b^2 = 1
\quad \Longrightarrow \quad b = \frac{1}{\sqrt{8\lambda^2+2}}
If we suppose that $\; 0 < \lambda < 1$ :
A(\lambda) = \lambda (b-c) = \frac{2\lambda}{\sqrt{8\lambda^2+2}}
It follows with elementary algebra that $\; A(\lambda) < 2/\sqrt{10}$ .
Now suppose that $\; \lambda > 1$ , then:
A(\lambda) = (b-c) = \frac{2}{\sqrt{8\lambda^2+2}}
It follows with elementary algebra that, again, $\; A(\lambda) < 2/\sqrt{10}$ .
Step 5. Asymmetric case.
Let $a = -2 k$ , $c = -k$ , $e = 0$ , $b = \lambda k$ . Then:
$$a+b+c+d+e=0 \quad \Longrightarrow \quad d = (3-\lambda) k$$
$$a^2+b^2+c^2+d^2+e^2=1 \quad \Longrightarrow \quad
k=\frac{1}{\sqrt{2\lambda^2-6\lambda+14}}$$
Two cases are distinguished:
\lambda < 1 \quad \Longrightarrow \quad
A(\lambda) = \max{(b-c)} = \frac{1+\lambda}{\sqrt{2\lambda^2-6\lambda+14}}$$
\lambda > 1 \quad \Longrightarrow \quad
A(\lambda) = \max{(d-e)} = \frac{3-\lambda}{\sqrt{2\lambda^2-6\lambda+14}}$$
We must prove that in both cases $A(\lambda) < 2/\sqrt{10}$ .
First case $\lambda < 1$ :
\frac{1+\lambda}{\sqrt{2\lambda^2-6\lambda+14}} < \frac{2}{\sqrt{10}}
\quad \Longleftrightarrow \quad
10 (\lambda+1)^2 - 4 (2\lambda^2-6\lambda+14) < 0
2 \lambda^2 + 44 \lambda - 46 < 0
(\lambda+11)^2-144 < 0
-23 < \lambda < 1 $$
This is well within the range $\; 0 < \lambda < 1 \;$ hence $\; A(\lambda) < 2/\sqrt{10}$ .
Second case $\lambda > 1$ :
\frac{3-\lambda}{\sqrt{2\lambda^2-6\lambda+14}} < \frac{2}{\sqrt{10}}
10 (\lambda-3)^2 - 4 (2\lambda^2-6\lambda+14) < 0
2 \lambda^2 - 36 \lambda + 34 < 0
(\lambda-9)^2-64 < 0
1 < \lambda < 17 $$
This is well within the range $\; 1 < \lambda < 3 \;$ hence $\; A(\lambda) < 2/\sqrt{10}$ .
Step 6. I should have read the question more carefully in the first place: a nice suggestion is there.
Because $\; A = \max{(\min{(e-a,d-e,b-c)})} \;$ and $\;a^2+b^2+c^2+d^2+e^2=1\;$ and $\;e=0\;$ it is clear that:
A \le \sqrt{\frac{(e-a)^2+(d-e)^2+(b-c)^2}{3}} = \sqrt{\frac{1-2\,b\,c}{3}}
Where the equality is valid only for the special case that $\; e-a=d-e=b-c $ .
Thus in all other cases the inequality is strict:
$$ \neg \; (\; e-a=d-e=b-c \; ) \quad \Longrightarrow \quad
A < \sqrt{\frac{(e-a)^2+(d-e)^2+(b-c)^2}{3}}
Depending only on $\;b\;$ and $\;c\;$. This proves that our special case is optimal and that $\; A = 2/\sqrt{10} \;$, provided that a rather strange condition is fulfilled in addition to the strict inequality:
$$ b\,c = - \frac{1}{10} $$
Step 7. Giving up. Because all of my steps toward full comprehension are clearly overruled by the
answer
with Christian Blatter as the author.
In case you didn't notice, it's peanuts now to complete the proof. So give Christian a firm upvote, as I did!
